Results 1 to 10 of 27
Thread: Stuck sump plug - oil extractor question
    Regular Member cheekylemon's Avatar
    Aug 2007
    Droitwich - Worcestershire
    Eek Stuck sump plug - oil extractor question
    Hi guys.
    I took my car for a service at Kwik-Fit (never again) and they have stated that they could not get the sump plug off. They then showed me the bent nut that now remains in the sump.
    Rather than them drilling the plug out, and risking damaging the sump and surrounding components I was going to buy an oil extractor (http://www.machinemart.co.uk/shop/se...tractor/page/1). Some cars seem to have restrictions in the sump when trying to stick a tube down the dipstick pipe, is there anything in the Vectra C (1.9 cdti) that would prevent the sucky pipe reaching the bottom of the sump?
    Also, is the oil filter on top of the engine like in Duncans post? (http://forum.vectra-c.com/showthread.php?t=15115)
    Thanks you brainy bunch!
    Richy B
    Regular Member DeanF's Avatar
    Nov 2007
    Staffordshire
    Can you not just go the Old fashioned route, A bit brutal, But normally works A Hammer & a Chisel
    Making sure you have a new one to replace of course !!!
    Dean
    Administrator Big-Pete's Avatar
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    as you said You can buy an oil drainer that goes into the dipstick and vacuum pumps the oil out, A lot of fleet mobile mechanics use them now, i see one being used used recently when my company astra was serviced, i think it was made by sealey and cost around £40 to £50 mark. I'd go with that rather than risk stripping the thread on the sump plig
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Just get a one of them self adjusting/tightening spanners, the more pressure you put on the tighter it gets. They will even undo a completely round nut.
    May 2008
    North West
    I once had a similar problem with a nut I needed to remove - I ended up using a dremmel and about 3 small grinding stones to grind 2 large flats on the thing and then a big adjustable spanner finally got the thing off. Took flippin ages but got there in the end!
    Aug 2007
    confused
    Thanks guys. The only things putting me off the oil extractor are the baffles in the sump which may prevent the pipe reaching the bottom, and the fact the oil filter is on the bottom of the engine.
    If the filter was on top, then I wouldnt have to get under the car. As I will need to get under to change the filter I may as well use the sump plug to drain.
    Where would be the cheapest/best place to get one of them spanner wotsits from?
    I think the kwikfit guys are worried about the two different metals being bonded together. I assume the sump plug is a different metal to the sump itself.
    Ashington, Northumberland
    Windy gun. It will shock it off.
    Aug 2007
    Yeah I think they will probably use one of them. I think they are scared of causing damage to the sump if the plug is bonded/cross threaded etc.
    I'll just let them sort it out I think. Bet I need to pay for a new sump!
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    when i worked in fast fit garages i use a air chisle on the washer part of the sump nut and that work every time
    Vehicle : SRi
    Mileage : 137000
    Quote Originally Posted by cheekylemon View Post
    Halfords, B&Q anywhere really, JML even do a set.
  1. Spark Plug & Sump Plug Torque setting - Z18XE Engine
    By wafoo in forum Engine & Drivetrain
    Last Post: 4th June 2012, 21:15
  2. Removing stuck sump plug
    By Big Knox in forum Engine & Drivetrain
    Last Post: 29th February 2012, 18:08
  3. Sump Plug Stuck Fast...
    By spoons in forum Engine & Drivetrain
    Last Post: 16th November 2011, 23:31
  4. Sump Plug
    By Tam80 in forum Engine & Drivetrain
    Last Post: 13th February 2011, 18:55
  5. Sump plug?
    By vec04 in forum Engine & Drivetrain
    Last Post: 10th December 2008, 20:58
vacuum oil extractor halfords
oil suction pump vectra c
