Thread: Brake pedal sinking with engine running
    Berks
    Default Brake pedal sinking with engine running
    I've just changed the brake hose and then bled my other half's peugeot petrol car. Took it for a spin to check everything was ok. I tested the brakes in several diffent ways and there was no leaks and brakes were functioning as they should.
    I then went for a drive in my Vectra 1.9 CDTI 120 (04 reg). I noticed that when my engine is off the pedal is very firm and does not travel/sink.
    However, when the engine is running the pedal sinks (slowly) when i press it. It brakes fine without any problems. In the peugot the pedal is firm with the engine running. I've pushed the pedal several times and it travels/sinks every time.... I've checked the brake fluid level and I'm not loosing any....
    I got a bit concerned because the peugot pedal didn't sink with the engine running....
    I found this on yahoo answer...it says its normal for diesels with ABS to get pedal creep (which I assume is pedal sinking).
    http://answers.yahoo.com/question/in...0081437AAstzZH
    Can anyone here confirm this is true for the vectra too? Does your pedal sink if you press it while the engine is running?
    First of all if it is a Diesel with ABS you will get pedal creep when pressing the pedal without driving.
    Does the pedal creep without the engine running if not then you do not have any external fluid leaks .
    If it does creep without the engine running then yes you will have an External leak.
    Please also check does the pedal creep whilst braking when driving if it does not then YOU DO NOT HAVE A PROBLEM.
    You see you could be trying to fix a problem that is not there . I consulted Peugeot Technical on a 605 over this matter and after changing everything they told me DIESEL ABS WILL HAVE PEDAL CREEP
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Diesel use a separate vacuum pump to create the brake assistance.
    If the brakes work fine and you're not loosing fluid, I wouldn't worry about it.
    Admin plasma's Avatar
    On the Forum
    213 Post(s)
    Engine : 150
    Mileage : 74000
    Quite normal nothing to worry about
    Berks
    Many thanks both of you.
    I can go to bed knowing that it's ok......was worried i had to get a new master cylinder!!
    All is good then...just hope the garage passes the MOT on the misses car tomorrow...It failed yesterday and they wanted £200 for changing the front brake hose, rear brake pads and also fit a missing clip for the fuel filter.... I paid £35 for the parts and did it myself.....makes me feel goooooood!!!
  2. For Sale: Vauxhall Insignia Brake Pedal Alloy Cover - SRI sports pedal cover
    Last Post: 20th December 2012, 21:36
  3. Brake pedal ?
    By Denbo in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2011, 01:47
  4. brake pedal
    By barrie m in forum Suspension, Wheels & Brakes
    Last Post: 12th February 2010, 21:21
  5. Hissing brake pedal
    By runs4miles in forum Suspension, Wheels & Brakes
    Last Post: 10th October 2008, 18:15
