Thread: new discs
    Regular Member signumboy's Avatar
    Edinburgh/outskirts
    Engine : 2.0 Ltr Turbo
    Mileage : 38000
    Default new discs
    well ive took the plunge and odered these today Zinc Coated Slotted and drilled brake discs think they will look the cats nashers anyone wanting my old set of discs which are perfectly good only done 20 k 302 mm front 292 mm rear they are yours for the postage
    Regular Member aaruck's Avatar
    Cheshire
    Vehicle : Insignia
    Anyone know if the discs will fit a GSi? If so, I'd love to take them off your hands. How much do you think the postage is?
    Edinburgh/outskirts
    Mileage : 38000
    Quote Originally Posted by aaruck View Post
    I,m not to sure about carriage cost my friend as they are quite heavy but i think you would be looking at 30 -40 notes
    rgds phil
    Regular Member Dwabo's Avatar
    Carterton, Oxfordshire
    postage will be around 25quid.. try parcel2go.com
    Regular Member signum junkie's Avatar
    Edinburgh
    Hi m8 are these bigger than normal for a Signum. If so I would be very intrested as I am looking for an upgrade Cheers!
    Edinburgh/outskirts
    Mileage : 38000
    Hi they are off a 2.0 turbo which i am told are bigger than others i think normal size is around 292 mm for front i am not sure about rear but these are 302mm front and 292 rear ill give you the pads also if you want them there tons of wear left on them yet
    phil
    pic there
    Regular Member shan's Avatar
    If your willing to split i'm interested in the rear's please.
    Edinburgh/outskirts
    Mileage : 38000
    Hi Shan
    dont want anything for them they are anyones for the taking ive just upgraded my discs to groove and drilled with the green stuff pads so you are more than welcome to whatever you want
    cheers phil
    I'll have the 2 rears if thats ok. I have no need for the fronts as i'm going to be getting 314's. Somebody else must have use for them.
    I'll PM you.
    Edinburgh
    Hi m8 have sent you a pm and Shan would be happy to split if thats OK cheers
  1. Discs
    By Tam80 in forum Suspension, Wheels & Brakes
    Last Post: 8th February 2011, 01:54
  2. Replies: 1
    Last Post: 21st October 2008, 15:11
  3. Can you fit 314mm discs to replace discs on back wheels of a GSi 3.2???
    By MAF 3.2 V6 GSi in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2008, 21:10
  4. Fitted for 314mm discs but fitted with 304mm discs
    By Swatty in forum Vectra C / Signum Car Chat
    Last Post: 10th April 2008, 13:19
  5. MP3 Discs
    By Trick202 in forum Electrical & ICE (including SatNav)
    Last Post: 21st February 2008, 19:21
