Results 1 to 10 of 11
Thread: lambda question
    Regular Member Morephun's Avatar
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    Default lambda question
    Does the vectra ecu recognise a dying(slow)lambda or will it just throw a fault when the lambda stops working altogether? As I have read that some cars will recognise a slow lambda and others wont....thanks
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    bump
    Regular Member joules2.0t's Avatar
    surrey
    Trim : SRI
    Year : 53
    Would have thought you would get the spanner light come on. Best bet is to take it to a dealer and ask em to Tech II it.
    Mileage : 55000
    I would have thought you would get the light come on too. This is my theory. The ECU has set perameters. If the Lambda is not working correctly it will tell the ECU incorrect data. If the ECU listened to the incorrect data ( and re-learnt it). you might find that it could tell it to over fuel and that eventually would distroy the CAT. Or even make the car run badly.
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    oh well I will replace mine anyway and see how it goes..thanks guys
    surrey
    Trim : SRI
    Year : 53
    What sort of things have you noticed that make you think it is the lambda..
    scotland
    I'm sure the emissions light will come on rather than the spanner one
    Mileage : 55000
    What about disconecting the wire from the Lambda and see if the same warning light comes on.
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    No guys Im not getting any light, A while after I got the car the emissions light came on. The garage I got it from ran a diagnostic and got a [sensor 1 bank 1]fuel trim so they cleaned the lambda.Have been told off of vauxhall that cleaning them can poison the lambda. Since then the car judders a bit like its missing when in slow moving traffic or low revs in any gear ,I was just wondering if anyone knew if the vec ecu would recognise if the lambda was not working correctly and a tech2 would only pick up a dead lambda.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    You been mis guided by VX again. The process of cleaning them WILL NOT poison them. The cleaning fluid might though! If you insist on cleaning it, then use a bit of petrol only. The sensor will be poisoned by phosphurous and sulphur.
    I don't think the ECM will detect a drifting lambda sensor until it goes out of range, then it will throw the light on, and revert to default settings (but not limited operation, I don't think) acceleration will be down, smoke will be up and so will fuel consumption.
    If you have a FC for oxygen sensor, then it's really best to replace it.
  1. EML 2.0T Lambda or CAT
    By a1ant in forum Troubleshooting
    Last Post: 20th August 2011, 20:53
  2. Cat Or Lambda
    By Tam80 in forum Vectra C / Signum Car Chat
    Last Post: 6th July 2011, 21:03
  3. Lambda question on 2.0T
    By ROCKATANSKY in forum Vectra C / Signum Car Chat
    Last Post: 1st September 2010, 22:47
  4. Lambda help
    By Barnes in forum Vectra C / Signum Car Chat
    Last Post: 28th January 2010, 20:42
  5. Lambda
    By VECTRAMAN in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2009, 10:33
vectra ecu lambda
