Thread: central locking not woking on work van
    Regular Member Gr4eme's Avatar
    Feb 2007
    Durham
    Default central locking not woking on work van
    can any of you peeps help???
    when i lock my doors by the key fob all the doors lock but then they unlock staright away like as though a door had been left open.
    its a cough 52 peugeot expert (no snide remarks please)
    any help would be appreciated.
    Feb 2007
    Durham
    anyone ???
    Administrator plasma's Avatar
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    sounds like the drivers side door thinks its still open...
    Regular Member mick307's Avatar
    Feb 2007
    midlands
    Check the wiring where it leaves the doors and goes into the car, sounds like a broken wire in there somewhere. The other thing to try is lock it using the key and see if that overcomes it.
    Mick
    Regular Member poves's Avatar
    lancashire
    Check the courtesy lamp pin which is on a spring in the doorframe is ok , if it is bent it will register the door is open and wont lock.
    Regular Member mitchell's Avatar
    northumberland
    defo sounds like the micro switch on the drivers door it knackered, but what do you expect from a pug graeme LOL. if it is the source of the fault quick fix wrap some electricians tape round the spade connector to block the circuit. HTH andy.
    Regular Member joules2.0t's Avatar
    surrey
    Trim : SRI
    Year : 53
    A mate had the same trouble on a pug 206. Clean and reseat all the spade connectors on the door solenoids.
    Feb 2007
    Durham
    Now fixed, I took apart the wiring connectors on the passenger and driver doors, sprayed the spade connectors with wd 40, reconnected them back together and now everything is working fine
    cheers for the replies.
    surrey
    Trim : SRI
    Year : 53
    Glad to have been able to help.
  1. Central locking
    By stevie16v in forum Bodywork & Interior
    Last Post: 21st March 2011, 18:56
  2. remote central locking doesnt work!!!!!!
    By Chippie19 in forum Vectra C / Signum Troubleshooting
    Last Post: 9th August 2009, 08:32
  3. central locking
    By whitevanman in forum Vectra C / Signum Car Chat
    Last Post: 10th July 2009, 08:06
  4. Central Locking Doesn't Always Work
    By kyedj in forum Electrical & ICE (including SatNav)
    Last Post: 22nd June 2009, 11:45
  5. central locking help !!!!!!!
    By VECKSZ in forum Electrical & ICE (including SatNav)
    Last Post: 14th April 2009, 17:37
