Results 1 to 10 of 16
Thread: OMG wheres my clutch pedal gone!
    Regular Member baztheman's Avatar
    washington tyne & wear
    Eek OMG wheres my clutch pedal gone!
    Hi all .... well after a very bad start with my veccy 1.9cdti 150 (new clutch and timing belt+ kit)
    i was taking the missus to work this morning and came to a roundabout pressed the clutch and the pedal stayed on the floor.
    had left my phone at hone ,no coat on,wifed phone battery flat,and it was peeing down with rain.
    police moved the car and took us home,called the aa and they have taken the car to the garage where the clutch was changed 2 months ago (if that)
    anyway reading the forum it sounds like a clutch spring on the pedal but not knowing alot about the workings of my veccy i was hoping somone on here has had the same fault and has solved the problem .
    the aa man said it may be the clutch cylinder but the clutch spring was overlooked.
    if the spring does go does the pedal just stick to the floor and if so is the pedal electronicaly controling the clutch (ie ok there is no return force there but if i tried to put it into gear would the clutch just be thinking it has been pressed and if i pulled the pedal up it would engage the clutch)
    cheers in advance...baz
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    not good m8, hope you get it sorted soon.
    Regular Member vectra 120's Avatar
    Washington Tyne & Wear
    Quote Originally Posted by lofty View Post
    good luck m8
    Sunny Dartmoor
    Gutted m8,lets hope its just the spring...........
    well just got off the phone and my m8 who has a vectra said it happened to him.
    he said the clutch pedal gets its depressing pressure from the hydrolic cylinder (as suspected) which shares the brake fluid resivoir,hopefully its part of the cluch warrentee (i would have thought if i payed £922 for the clutch repair that the hydrolic clutch cylinder had been changed,if not ile be asking why?)
    cheers...baz
    If you paid £922 for a clutch repair what the hell were they charging you for if they didn't change the slave cylinder/thrust bearing?!! They should've really changed that - certainly worth seeing if they did.
    Somewhere I probably shouldn't be
    OMG, I just got worried! I noticed that I've not got a clutch pedal, wheres mine gone????
    ....It's ok, just remember, I've got an Auto.
    Sorry, one of those moods today
    Update....
    well it was a pipe had sprung loose on the control box which leads to the clutch bell housing,some clip had failed which cost £30 (not to bad after all)
    all parts in the clutch were replaced first time around.
    cheers...baz
    Good news Baz glad it's sorted buddy !!!!!
    I just thought i should add this info to round this thread off!
    well the pipe came loose due to 3 bolts not being replaced and left on the plastic engine pan,which in turn caused my engine to rock around and also in turn caused my earth lead to loosen .
    all was rectifyed when i took the car back to the garage where i had the clutch done... grrrrr... baz
  1. clutch pedal really soft after new clutch
    Last Post: 3rd February 2013, 14:52
  2. Replies: 11
    Last Post: 1st August 2012, 15:48
  3. Clutch pedal
    By BigWilko in forum Engine & Drivetrain
    Last Post: 9th January 2011, 08:38
  4. Clutch Pedal!!
    By andd306 in forum Vectra C / Signum Car Chat
    Last Post: 25th March 2010, 21:48
  5. Clutch pedal
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 8th July 2008, 23:53
