Results 1 to 3 of 3
Thread: Holding gears
    Apr 2008
    Brisbane Australia
    Default Holding gears
    Hi All,
    Hoping someone might be able to advise re a problem I have with the auto box on my Holden Vectra CDXi. (3.2 V6, 66,00Kms)
    A year or so ago, I had the auto replaced (under warranty) due to erratic changes, a problem which has been documented on this forum before.
    Since then, I have had the following problem:
    If the car has been stopped (like at traffic lights) with the nose higher than the rear, when I move off up any sort of incline, the auto will stay in first gear and will not change up despite picking up speed - even if the road levels out or even falls away downhill. At times, I have had to stop the car completely and start off again, after which it changes up fine. If I can't stop (if there is traffic behind) I have to drive along at a slow speed so that I do not over rev the engine until I can.
    Car has been in at a GMH dealer more times than I can remember and I have written to GMH H/O. Final word back is that "other Vectras do the same thing", "these auto boxs do this - they are very complex".
    Has anyone come across this problem before??
    Car is fantastic otherwise.
    Cheers!
    Al
    Brisbane, Australia
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Cannot be that complex then if it cannot work out when to change gears!
    I would suggest you take it up with your local trading standards (if there is such a thing in Australia) as the gear box is not fit for use and you have proof in the letter back from GMH
    Apr 2008
    Brisbane Australia
    Sorry, I should clarify that it was the GMH dealer who made the comments and not GMH themselves. My next step is to go back to GMH Australia and tell them again that all is not well.
    Cheers!
  1. Battery not holding charge
    By Froggy in forum Electrical & ICE (including SatNav)
    Last Post: 7th February 2013, 15:21
  2. Holding back
    By obews in forum Engine & Drivetrain
    Last Post: 29th December 2012, 10:22
  3. Engine holding back
    By paul4400 in forum Engine & Drivetrain
    Last Post: 6th June 2011, 00:40
  4. Fuel filter holding
    By JKB89 in forum Vectra C / Signum Car Chat
    Last Post: 7th September 2008, 14:37
  5. Just holding my hands up
    By Ben H in forum Billing 2006 8/9th July
    Last Post: 2nd July 2006, 14:42
