Thread: Split pipe or is it worse?
    UK
    Thumbs down Split pipe or is it worse?
    Hi
    I'm hoping this is a simple fix but need some advise please. My CDTI 1.9's turbo doesn't seem to be kicking in until over 2500 RPM and I can hear a slight blowing noise from the engine bay. Had a peek under the bonnet when i just got back home and it smells a lot of fumes on the right hand side of the engine next to the battery, theres also a fair bit of black sooting on the right hand side injectors.
    I'm hoping its a split pipe and will have to take a look in the day light tomorrow, but has anyone had a pipe split somewhere down there, or can anyone tell me what to look for around that area?
    Full Member plasma's Avatar
    On the Forum
    346 Post(s)
    Engine : 150
    Mileage : 74000
    cant recall any members having split pipes on the 1.9cdti... plenty on the 2.2dti's though. cant think whats on the right hand side what could be causing this, aint seem under my bonnet for a little while. Maybe when you have a look tomorrow take some snaps and put them up or something and i'll get under my bonnet tomorrow when i get home from work and figure out whats around that area
    UK
    I'm hoping its not a blown head gasket or something
    UK
    It seems to be the corrugated pipe going from the top of the exhaust manifold round to the right hand side of the engine. Is this for the EGR? Sticking my fingers down by whatever it joins to you can really feel a blowing. The water pipes make it a bit restrictive to see it and I couldn't remove them as I have no coolant at home. Hoping its just the case of sticking a new pipe on!!
    On the Forum
    346 Post(s)
    Engine : 150
    Mileage : 74000
    totally forgot about looking tonight sorry.. will have a look tomorrow..
    UK
    Damn, that pipe at the front fell off this morning on the way to work, popped into the dealers and they want £116 just for that front pipe
    Regular Member vockycdti's Avatar
    May 2007
    stoke
    i have the same problem on mine,have you had it sorted? how much did it cost m8....cheers
    UK
    It cost £116 and I did it myself, it looked fairly easy but i had to remove the coolant pipes etc to get better access
    May 2007
    stoke
    cheers for the reply cookie, would you recomend doing it myself then m8
    or pay the garage to do it??
    UK
    oh yes, do it yourself, it doesn't warrant a garage doing it, just get ready to keep loosing the new seal down the engine bay everytime you try to fit it in place, lol. damn seal. You might want to drain the coolant as it makes it a little easier to get to the EGR pipe then.
  1. fuel pipe split.....cdti
    By mark the hat in forum Engine & Drivetrain
    Last Post: 13th November 2016, 12:06
  2. Split pipe? Which one is the intercooler?
    By Chunklamb in forum Engine & Drivetrain
    Last Post: 3rd January 2013, 21:59
  3. Split pipe
    By LeeU in forum Diesel Engine related
    Last Post: 10th September 2011, 20:38
  4. split pipe
    By pacman696 in forum Engine & Drivetrain
    Last Post: 6th June 2011, 21:04
  5. Anyone had a split air intake pipe from MAF?
    By Phil MC in forum Engine & Drivetrain
    Last Post: 11th June 2009, 11:07
