Thread: Heatings gone
    berkshire
    confused Heatings gone
    My heating has gone from hot to just luke (if i'm lucky) warm.
    There's water in the system so not losing any there but thought could have air lock so i emptied it and refilled it,still nothing.
    If i sit in traffic the temp gauge goes to half way but no more than that.
    Both the water pipes going from engine bay into car are hot.
    Could it just be thermostat that needs replacing? Any idea's would be helpfull as i cant get my car booked in to vauxhall's till 12th.
    berkshire
    Soz forgot to mention its a 2.0 dti.......
    berkshire
    confused
    Quote Originally Posted by Sparky View Post
    Anyone ?????
    Administrator plasma's Avatar
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    Is the engine/temp guage still moving as per normal? Check the pipe which leads away from the thermostate when the car is just started.. should be cold... if it warms up at the same temp as the rest of the pipes then it could well be the thermostat.. the pipe leading away should get hot all of a sudden like when it opens..
    berkshire
    confused
    yeah temp gauge still sits at normal till i sit in traffic then goes up to half way but no further than that, i noticed today it went to half way when i built up speed on motorway then went back down again ?????????????
    I'll check in morning when i start it up and see what happens.
    Thanks plasma..............
    Regular Member Vaux-Man-G's Avatar
    Birmingham
    THis happened to me in a 1.7 TD, dont know if the situation is the same, but I had to replace the thermostat, apprently it kept sticking and the air was not getting hot at all, even with the car stood in traffic for 15 mins! Sometimes if I tapped the outer casing of where the thermostat was located, it used to warm up for a short while, but then it used to lock up again on the next usage. More than likely going to be this I should think, but I dont know where it is located on the 2.0 DTI. HTH.
    berkshire
    Thumbs up
    Quote Originally Posted by plasma View Post
    Just checked it when i started it up and yes the pipe leading away seemed to warm up as the rest but not as warm as the others if you know what i mean.lol.
    berkshire
    Thumbs up Fixed
    Fitted the new therm housing today and it's done the trick, hot air at last not that we need it at the mo...
    Thanks to everyone for the tips..........
