Thread: Oh botty - stripped rear caliper guide pin?
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Default Oh botty - stripped rear caliper guide pin?
    On trying to take the rear pads out today, the upper caliper guide pin on the o/s was very tight to undo. Compared to how easy the bottom guide pin came out, I knew something was amiss.
    After greasing the new pads up, put the caliper back on and the bottom guide bolt went in fine. The top one was very tight and, although I was careful, I think I've stripped the thread on the bolt and the thread on the carrier.
    Can I just buy a new guide bolt and re-tap the carrier or is it a new carrier job?
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    if the pad carrier thread is stipped then it will need a new one but i think its part of the hub
    or you could try a helicoil as these can work very well indeed. i have used them on spark plugs and for cylinder heads bolts
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Quote Originally Posted by glynn View Post
    Just about to start crying (big time). I've consoled myself that as it was difficult to come out, the damge was probably done by someone else and I'm left to clear up
    Quote Originally Posted by gtr1000 View Post
    its called sods law m8 hope you get it sorted dont know if halfords sell the as i think they are the same as fords
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Good news (perhaps?) - mate at VX looked on TIS and it looks like carrier is a separate item (connected to hub carrier by two bolts).
    Will phone VX on Monday and check price - guessing @ £20 million plus VAT
    yep, they are a seperate part and just two E18 bolts to swap it....
    or, you could try an M8 tap in it to see if you can recover the thread enough..
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Thanks Mark (as always). , just what I'd hoped.
    Mileage : 000
    I can lend you an M8 Tap if you need one .I can post it to you if need be, just give me a shout.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Quote Originally Posted by ed taylor View Post
    Hi Ed - I'll have a closer look at the problem over the next few days. I'll certainly bear your kind offer in mind. If I need the tap, I'll PM you with the relevant details.
    Thanks once again.
  1. rear caliper
    By roverjay in forum Engine & Drivetrain
    Last Post: 5th January 2013, 17:20
  2. Rear caliper
    By jodiexii in forum Y & Z30DT Specific
    Last Post: 23rd September 2012, 09:42
  3. Caliper guide bolts
    By vec04 in forum Suspension, Wheels & Brakes
    Last Post: 28th May 2009, 23:23
