Thread: aftermarket stereo
    Regular Member stuart bigboy's Avatar
    May 2007
    kent
    Default aftermarket stereo
    hi there i have just changed the head unit in my 04 gsi tested all the wiring before doing so and on the cars loom i have apermenent live and an ignition feed both with 112 volts . but when i plug the stereo in i loose the ignition feed am i doing something wrong or is this what happens with the vectra or do i need to buy more leads #
    any info would be helpfull
    Jul 2006
    AFAIK there's no ignition live because it's all done by CANBUS. If you need a switched live, you'll have to run one from the 12V accessory socket.
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    An 04 could have an ign live if it's half canbus,try taking a supply from the cigar lighter that normally okay.
    Quote Originally Posted by stuart bigboy View Post
    I hope thats a typo
    On my stereo i had to swap the yellow and red wires round to make my JVC unit work (also an 04 model )
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    but my head unit is a sony one
    Midlands Mod Shop - NFFC.
  1. aftermarket stereo cut out
    By Allan-DTI in forum Electrical & ICE (including SatNav)
    Last Post: 19th June 2012, 19:55
  2. which aftermarket stereo
    By a6lns in forum Electrical & ICE (including SatNav)
    Last Post: 22nd October 2010, 18:50
  3. Aftermarket stereo
    By tubby in forum Electrical & ICE (including SatNav)
    Last Post: 11th September 2010, 15:20
  4. Aftermarket stereo
    By tditony in forum Electrical & ICE (including SatNav)
    Last Post: 29th November 2009, 11:39
  5. aftermarket stereo
    By stevietiger in forum Electrical & ICE (including SatNav)
    Last Post: 11th November 2005, 11:36
