Thread: door handle problem
    Regular Member decks's Avatar
    Apr 2008
    nothern ireland
    Vehicle : 2.0t btcc
    Default door handle problem
    was fitting my chrome door handles and the torx screw that you undo to release the handel fell inside the doorcard, does anybody know the exact size of screw it is, dont want to be driving with 3 chrome handles and one missing.
    best thing to do it take the door card off... the screw isn't a 'conventional' one so you'll have to recover the original..
    the door cards aren't hard to get off ..
    Apr 2008
    nothern ireland
    Vehicle : 2.0t btcc
    was trying to avoid takeing doorcard off as never done it before, would vauxhall have the screws.
    they are part of the door handle carrier assy which you would have to buy and then remove the doorskin to fit anyway....
    the skins aren't hard to remove.. two hidden fixings inside the door pull handle ( the front comes off to reveal it) .. then 3 screws at the bottom of the door..
    the rest is popstuds...just unclip them out of the door...then you have to push the trim up, off the top edge of the steel door frame.
    all thats then left is to disconnect the door cable release ( pull the outer back and flip it up before taking the steel peg out of the handle) and disconnecting the speaker cable and window power cables..
    if it's got a window winder in the door card, there is a C clip on the back that you will have to prise sideways to remove the handle..
    Apr 2008
    nothern ireland
    Vehicle : 2.0t btcc
    well got the screw but the handle will not tighten back into place i have tried everythi ng, i dont know if i have lost a spring or something, looks like i will have to go to vauxhall, the other handles were no probs i tried for hours with the last one with no joy.
    Apr 2008
    nothern ireland
    Vehicle : 2.0t btcc
    still no joy with the handle,it just wont fall into place when you tighten the torx screw, i must have messed something else up inside the lock recess ,hope vauxhall dont make a meal of it if i take it to them, mite go to local scrappy and see what i can find.
  1. LED door handle mod ( outside )
    By bobsimes in forum Electrical & ICE (including SatNav)
    Last Post: 27th November 2012, 13:30
  2. Problem with rear door handle
    By beethamwest in forum Vectra C / Signum Car Chat
    Last Post: 12th June 2010, 21:33
  3. OSR External Door Handle & OSF Door Lock
    Last Post: 29th May 2009, 17:14
  4. door handle
    By decks in forum Bodywork & Interior
    Last Post: 17th June 2008, 12:05
  5. door handle problem
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 13th June 2008, 18:09
