Thread: Cam belt?
    Oct 2007
    Gloucester
    Default Cam belt?
    My car's recently rolled past 63000 miles and seems to be fine (touch wood). Now, last time it was serviced (January - main dealer), I enquired when the cam belt needed changing. The clueless dolly behind the counter said 80k, but I keep hearing people saying it's best to change at 40k, 60k etc. What is the best time? And what sort of cost would I be looking at (1.9cdti 150)?
    On another note, what tyres should I be looking at as my fronts are becoming borderline legal? I'm not after a specific brand or type - plenty of those threads on here!! - and I know I need 225/45/17 but more the specific type e.g. speed and load ratings. Any help greatly appreciated.
    Regular Member simac's Avatar
    Wirral
    40k is best for the cam belt to be safe, IIRC the rollers or tensioners can dry out and fail is you leave it to 80k.
    With the tyres, i'd just fit the same rating and size that's already on
    Oct 2007
    Gloucester
    I would keep the tyres the same, but the car's running on the 215/50/17s at the moment and there are very few choices for that size.
    Aug 2006
    Is a very naughty boy
    91W will more than be enough for your car.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    100k is the service interval for the cambelt on your car which is the same as mine. A word of warning tho as my cambelt tensioner went at 61k and took the engine out. New engine under warranty tho . I think I would get it done at 60k
    Regular Member parapaul's Avatar
    Jul 2006
    And change your tyres for 225/45 - cheaper and much wider range
    Technical directors office
    i can only echo the early cambelt change recommendation... why put off spending out £200 on a belt change when it can cause £000's in damage..
    and tyres... swap to 225/45 and you can save up to £50 a tyre..
    i used to buy 215's for £125.. now i have 225/40/18 for under £90 a corner (continental's which are terrible.. don't buy them)..
    Regular Member Gaz the Cab's Avatar
    Nov 2007
    Chester
    Quote Originally Posted by merikiito View Post
    I have just had a tensioner seize after 18k miles, fortunately no harm done.
    Oct 2007
    Gloucester
    Looks like it might be an expensive month then!!
    Firstly, how much am I looking at for a cambelt and water pump replacement?
    Secondly, I've seen Goodyear F1 asymmetrics for £83 each from either Camskill or mytyres. Anyone had any dealings with them? And are they a good tyre?
    So many questions!!?!??!
    Jul 2006
    Quote Originally Posted by bigknill View Post
    Parts for cambelt etc come to around £200, then labour on top of that.
    F1's are superb tyres. Quiet and stick to the road like turds to a blanket
  1. 1.9 cam belt
    By J P S in forum Engine & Drivetrain
    Last Post: 18th February 2012, 12:13
  2. Belt changes on a 1.8 VVT
    By PeterVV in forum Engine & Drivetrain
    Last Post: 27th April 2011, 21:53
  3. Fan belt / Drive belt
    By patdavis in forum Engine & Drivetrain
    Last Post: 8th January 2011, 00:39
  4. drive belt or fan belt
    By geebee007 in forum Electrical & ICE (including SatNav)
    Last Post: 17th September 2008, 10:23
  5. fan belt ??
    By arniedavo in forum Engine & Drivetrain
    Last Post: 10th September 2008, 01:16
