Results 1 to 10 of 26
Thread: Sat Nav System
    Regular Member ADAM123's Avatar
    Jan 2008
    UK
    Default Sat Nav System
    hello again, i apologise for flooding the forum with my questions
    i own a 2003 vectra sxi 2.0 dti with a cdr2005.
    i have just purchased the following sat nav kit from ebay and was hoping to retro fit it.
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWA:IT&ih=015
    i'm an absolute novice and was wondering what else i need. i know i need a nav aerial base and require a tech2.
    if i buy a nav aerial base, will it connect using my existing cables within my roof lining? will i need any other looms etc?... i would really appreciate if someone could help me please. has anyone on here done this upgrade before?.....many thanks in advance. adam
    Full Member Big Sig's Avatar
    I think there maybe a few canbus issues there as yours is half can bus and I think thats a full can bus unit.
    Here, there and every where!
    Sorry to disappoint m8 but as yours is half CANBUS you can't fit that system into your car
    i think that there's a big can of worms coming your way.....
    there's too many 'issues' with installing it for it to be plug n play, or even a straight forward fit...
    was the unit properly removed using tech2?.. can this be verified?
    the cabling will be different.. chris gettings priced this up at over £1800..just to convert to full canbus
    if you do pull this off it'll be a first... good luck, but i think the headache is just starting....
    Jan 2008
    UK
    'kin hell! should have researched before hand. i'm not gonna pay for it as it was described as plug and play.
    really appreciate your help
    It would be plug and play, into the right car.
    Jan 2008
    UK
    whats canbus?
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    Taken from the eBay listing:
    "EASY AND SIMPLE INSTALLATION
    PLUG AND PLAY , TAKES AROUND 10 MIN TO INSTALL"
    1. some have done it, but it is not easy see: http://forum.vectra-c.com/showthread.php?t=44828
    2. but as it comes from an Astra, the display will not fit
    3. changing the display will not work, because it comes fom a breakers and pretty sure it has not been tech2'd out of the car
    Canbus is the way all the ecu's talk to each other in the car, if ones missing or wrong it throws up a fault.
    They didn't come from an Astra either That display is for a Vec/Signum (Astra is totally different) and the head unit is the wrong shape to be an Astra one too
    Still won't fit yours though unfortunately m8.
  1. What a cr@p system !
    By FIL 4822 in forum General Chat
    Last Post: 22nd December 2012, 16:46
  2. Csa Changes to System ?
    By spennny in forum The 'Off Topic' room
    Last Post: 25th January 2012, 22:41
  3. BRC LPG System
    By Aidi in forum General Chat
    Last Post: 23rd January 2012, 10:20
  4. Which nav system is this
    By Shogun in forum Electrical & ICE (including SatNav)
    Last Post: 27th August 2011, 10:41
  5. DTUK multimap power system and red power system - opinions please :D
    By Princess D in forum Diesel Engine related
    Last Post: 13th December 2010, 01:03
