Results 1 to 3 of 3
Thread: Changing Rear Discs
    Jan 2008
    Bolton
    Default Changing Rear Discs
    I have been looking at many threds about changing the pads,
    Including the warning about the Piston Return Tool.
    Can find anything about the Discs.
    Can I just Remove the pads, Remove the Securing screw and the disc comes of.
    Or do I have to take off any more of the caliper.
    Jul 2006
    IIRC you have to take the caliper off to change the disc... but don't quote me, it's not something I've done yet.
    yep, take the caliper off ( two 7mm allen bolts) and dependant on which discs you have you may have to also take off the caliper carrier bracket (two E18 bolts).. apart from that it's just the securing screw and a hammer to tap the disc off..
    don't forget to clean the hub face off very well (back to bright metal) before fitting a new disc to avoid brake judder
  1. changing discs and pads, pushing pistons back.....
    By taffy bhoy in forum Suspension, Wheels & Brakes
    Last Post: 9th October 2012, 22:33
  2. Changing brake discs?
    By amen in forum Handling & Braking
    Last Post: 16th July 2012, 20:33
  3. Changing rear pads and discs on Vectra 3.2. is it Easy?
    By vec3.2 in forum Vectra C / Signum Car Chat
    Last Post: 20th August 2009, 22:10
  4. Changing Front Brake Discs
    By rozzer1976 in forum Suspension, Wheels & Brakes
    Last Post: 17th August 2007, 22:09
