Thread: 6x9's and 130mm speakers plus amp?
    Regular Member rosssri's Avatar
    S.Lanarkshire
    Default 6x9's and 130mm speakers plus amp?
    Just found a bag up the loft with my old JBL 6x9's and Pioneer 130mm speakers and a Pioneer amp (from my younger days ).
    Anyway would it be possible to fit these into my 55 plate vectra sri without having to cut holes in parcel shelves etc (which used to be a regular thing). The set up used to sound great in my old Nova sri .
    Just wondering if fitting these would be worth while or would i be better to leave the standard set up in the car as i have no intention of changing from the standard head unit?
    I know the 6x9's will be a ****** to fit anywhere so will the pioneer 130mm speakers fit anywhere? (if memory serves me right they were expensive all those years ago)
    Full Member lochgilp's Avatar
    argyll
    i doubt you will get the 6x9's in anywhere mate unless like u say cutting the parcel shelf and as for the 130mm Pioneers speakers im afraid they are no use either as the vec takes 170mm Speakers
    hope that helps
    Jul 2006
    I dare you to copy and paste that over on TA
    With the kit you've currently got why are you even thinking about 6x9's? And unless you can make some very creative baffles for the rear doors, the 130mm speakers won't fit. Standard size is 165mm same as the fronts.
    HTH
    Regular Member alzsxi's Avatar
    Maidstone, Kent
    Go for the set up you like mate. Peoples' car sound systems are a matter of personal taste, what sounds good for you is all that matters.
    As for the speakers you MIGHT be able to fashion a decent baffle out of MDF.
  1. Are 6x9's chavvy???
    By ridgers84 in forum Electrical & ICE (including SatNav)
    Last Post: 10th May 2012, 17:59
  2. 6x9's
    By twaiter in forum Electrical & ICE (including SatNav)
    Last Post: 14th June 2010, 19:15
  3. Which 6x9's?
    By Keithy in forum Electrical & ICE (including SatNav)
    Last Post: 28th February 2008, 18:00
  4. 6x9's in a Saloon ?
    By Merick in forum Electrical & ICE (including SatNav)
    Last Post: 26th March 2007, 14:03
  5. 6x9's wiring
    By R13hard in forum Electrical & ICE (including SatNav)
    Last Post: 5th November 2006, 15:59
