Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: Help !!!!!!!
    space
    Default Help !!!!!!!
    Help me please have been up since six as i was disturbed by a car alarm,mine,but the alarm will not shut up,have turned the engine on and locked the car several times but it still keeps activating help me please
    space
    anyone realy annoying now
    Admin plasma's Avatar
    On the Forum
    325 Post(s)
    Engine : 150
    Mileage : 74000
    constantly go off? or going off 30 secs after you reset it? check rear windows on the estate make sure the sensors for the break glass havent come off. You may be able to disconnect the alarm siren, think its a plug, inside the left hand side cubby hole.. May give u some time to figure out the cause.
    space
    thanks plasma have checked all that seems to be ok,it goes of about 30 secs after locking
    space
    On the Forum
    325 Post(s)
    Engine : 150
    Mileage : 74000
    in the boot. thats where the module sits... try to disable the interior sensors.. its the button on the dash with a picture of a man running away i think. failing that it could be a tilt sensor. May need to get alarm code read to see what is setting it off
    Think to lock car without setting alarm. go in through passenger door, shut door using button on door card then shut passenger.. not sure but think this way it wont arm the alarm
    space
    done theinside sensor stil lgoes off
    space
    that was my next port of call,guy i now is a machenic has all the code reader gubbings
    On the Forum
    325 Post(s)
    Engine : 150
    Mileage : 74000
    on the alarm section it will tell you exactly which sensor/device is setting it off. off to work myself now, so good luck with it and let us know the outcome
    space
    Quote Originally Posted by plasma View Post
    thanks for your help plasma am now going to see my m8,hopfully he can sort it out as i dont realy want to go to vx and pay through the nose
