Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
Thread: Car light with spanner ...
    Jun 2007
    Sittingbourne, Kent
    Default Car light with spanner ...
    When i put my key into the ignition the car light with the spanner comes on then when i start the car it goes off what could the problem be ???
    I ve have the problem before with my 2.2 sri years ago but then the light stay on took it to vauxhall and they sorted it out saying they plugged it on the computer to sort it out as it needed updating ...
    it's just got an old minor fault code stored...nothing too much to panic about..
    it's only a big prob when it won't go out at all..
    Jun 2007
    Sittingbourne, Kent
    Will this continue to happen or go off after a while ??? just a bit annoying as it keeps catching my eye everytime i get in the car . should i go to vauxhall to sort it out??? (warrenty run out now so £50 i guess to put on machine) Car is running fine infact it ain t felt this good since i first got it
    it'll go of it's own accord when the fault 'times out' ... and yep, if you want a dealer to clear it , they'll want £50 off you... unless you know someone local who can wipe if off for you..
    Jun 2007
    Sittingbourne, Kent
    Regular Member v6boy's Avatar
    PRESTON
    Trim : GSI
    My spanner light kept coming on with the ignition then going off when i started her up. Drove me nuts. I just disconnected the battery for a while and hey presto no more spanner light. I think I'd caused it to come on once when i started the car without the MAF sensor connected. Must have upset something.
    Jun 2007
    Sittingbourne, Kent
    Quote Originally Posted by v6boy View Post
    How long did you disconnect the battery for mate ???
    11 Post(s)
    Took nearly a month for mine to stop staying on until the engine was running after I had a problem with the immobiliser which triggered the fault in the first place.
    Didn't bother me at all once someone on here confirmed that all it was doing was indicating that a fault code was stored in memory.
    Plenty of other check lights remain on until the engine is running (oil pressure, alternator, to name but a couple) so why let this one bother you? Surely they don't annoy you as well?
    Important thing is that it goes out when the engine is running.
    EVERYWHERE
    Quote Originally Posted by MAF 3.2 V6 GSi View Post
    15-20 mins usually does the trick.
    EVERYWHERE
    It takes 40 'warm-up' cycles for the fault to clear,as long as the fault doesn't reappear during that period.
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Problems with Air bag light, ABS, Anti Skid & Spanner light
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:23
  3. Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:57
  4. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  5. spanner light then engine management light
    By learoy69 in forum Engine & Drivetrain
    Last Post: 12th March 2010, 20:10
vectra c 3.2 spanner light
