Thread: Adjusting rear disc cover
    Regular Member grumpano's Avatar
    North West
    Default Adjusting rear disc cover
    Hello chaps.
    The rear brakes are squealing like mad when the car warms up. If i apply the brakes the noise stops. brakes off and the passenger side squeals. So i think it may be the gard thing surrounding the disc. How do i adjust this to see if its the problem.
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    sounds like you need new pads m8 or a good clean best get them check asap
    North West
    Had the discs and pads changed about 2000 miles ago by a local garage. The parts are from VX mate.
    Jul 2006
    I'd agree with Glynn - check the pads have got a decent coating of copaslip on the backs. That's pretty much always the cause of brake squeal.
    HTH
    It will not be the crud guard matey it will more than likely be the inside brake pad take it back to them and ask them to re-fit it properly as it has a spring clip that has to slip over the piston otherwise it will sqeel like a goodun
    PS if it was the guard it would do it all the time not just when braking
    North West
    Ok ta lads will call in on my way to work tomoz
    North West
    OK quick update brakes all cleaned and re greased. Seem to be fine now..
    Here, there and every where!
    ......ain't this site great
    North West
    Sure is.Thanks again lads.
    Sunny Dartmoor
    Had the same problem on mine,thought the pads were worn out,took them out cleaned up and greased and reassembled,bingo,no noise,this site is the best........
  1. Adjusting rear brakes?
    By Bigtee in forum Vectra C / Signum Car Chat
    Last Post: 8th September 2011, 07:29
  2. Adjusting the rear hatch
    By Derek Mc in forum Bodywork & Interior
    Last Post: 2nd January 2011, 22:21
  3. Replies: 3
    Last Post: 25th March 2009, 14:02
  4. rear disc and pad set ????????
    By mark the hat in forum Vectra C / Signum Car Chat
    Last Post: 31st December 2008, 19:31
  5. Rear disc & pad set
    By yorkshireborn in forum Vectra C / Signum Car Chat
    Last Post: 13th September 2008, 22:18
