Thread: Meta parking sensor help
    Regular Member eaglepva's Avatar
    Up North
    Default Meta parking sensor help
    Fitted the meta parking sensor thing to the siggy the other week but never wired it up untill the other day, but when i put the car into reverse the sensors constantly beep even when their is nothing behind the car, anybody know what ive done wrong?
    cheers
    Regular Member JuzzyD's Avatar
    Jun 2006
    Somewhere...
    Have yo gone back through the wiring to check the sensors are plugged in the right order?
    Is there anything stuck/obstructing the sensors?
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    Are they too low down or tilted towards the ground?
    Regular Member DeanF's Avatar
    Nov 2007
    Staffordshire
    Quote Originally Posted by Ian S100 View Post
    On the Meta system i fitted you could adjust the sensitivity & the Offset.
    Sounds like it is sensing something, Try to adjust whilst in reverse etc.
    Dean
    May 2008
    Worcester
    If you don't have the instructions you can get them from the meta systems site, you will need to register
    http://www.metasystem.fr/index.php/msy_ita_en
    then select the tech area tab
  1. Meta 2 - Rear Parking Sensor - Good Price ?
    By mickyd98 in forum Electrical & ICE (including SatNav)
    Last Post: 9th March 2008, 11:33
  2. Meta Rear Parking Sensor
    By 2.2direct-sri in forum Vectra C / Signum Car Chat
    Last Post: 24th January 2008, 22:52
  3. Anyone fitted Meta Targa SR2 Number Plate Parking Sensors
    By Marky in forum Vectra C / Signum Car Chat
    Last Post: 13th June 2007, 17:28
