Results 1 to 10 of 18
Thread: Engine cutting out when braking
    May 2008
    Scotland
    Default Engine cutting out when braking
    ....althought I think its an electrical fault.
    Basically, car is a 1.8 16v "s" reg (i think 99 is way off, wasnt thinking when registering) automatic vectra hatchback....and just blanked on the trum level, if that makes a difference at all.
    Problem is the car is cutting out when ever breaking, everything shuts down including power steering. Any ideas what the problem is?
    It happened a few weeks back, and I've got in mind that the lambda sensore was replaced (its my parents car and being a typical late teens/just 20 i zone out when they are speaking to me) and this more or less sorted the problem, apart from cutting out a couple of times when just sitting in traffic.
    So to go back to my question due to my blabbering:
    What is causing the car to cut out when breaking?
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    what does your engine normally idle at? it may be too low.
    May 2008
    Scotland
    mmmmh...good question, it did seem lower than usual, I want to say 1500, but in all honesty i might have said this tie round it was low as just 500.
    @home
    Engine : 1.9 CDTi
    I think it should be around the 10000 mark..
    May 2008
    Scotland
    missed off zeros.
    I honestly couldnt tell you as I wasnt driving and my mum as trying to keep the revs high.
    Regular Member LJ sxi-nav's Avatar
    Winchester
    my old vec-b used to stall sometimes when stopping at lights/junctions (not under normal braking, just when coming to a complete stop). I cleaned up the Throttle Body Housing and it imporved the situation. I had the X18XE1 engine (1.8 petrol). iirc the job itself is simple if its the same engine/problem - 4 bolts hold the throttle body to the engine, under the plastic cover, undo a few pipes & connections and give it a good clean. There is a paper gasket underneath, I just made a new gasket using gasket paper before re-fitting. Shouldn't take long to do at all. HTH.
    Also - mine used to idle 800 - 1000 rpm, but before I cleaned the Throttle Body Housing it would sometimes 'hunt' i.e. vary the revs between 500-600 and 1200. If it dropped as low as 500rpm, that is when it sometimes stalled.
    May 2008
    Scotland
    mmh, i might hint at mechanice if "cleaning out the engine would help?"
    no way would i be able to do it myself.
    Winchester
    i've not had the car for a while now, but as far as i remember it is not difficult at all. I'm sure the instructions for removing the Throttle Body Housing are in the haynes manual, so might not be a bad £18 investment.
    also - see if there are any engine trouble codes stored (I had an "Idle Control Valve - open circuit or wrong voltage" code i think it was), get them read either by someone who has a code reader, or at a garage.
    Full Member Big Sig's Avatar
    With it being an auto i guess it drops to idle when braking? Never driven one so have no idea. I guess its a x18xe engine, these are known to require the throttle body cleaning out. An easy and quick job.
    May 2008
    Scotland
    cheers, i'll suggest that to the mechanic
  1. Insignia 2.0 CDTi - engine braking ???
    By vxinsigniaboy in forum Insignia car chat
    Last Post: 15th August 2011, 21:37
  2. Replies: 3
    Last Post: 28th April 2009, 19:49
  3. Engine cutting out
    By Dano2808 in forum Engine & Drivetrain
    Last Post: 26th March 2009, 13:33
  4. Engine cutting out
    By Sean-2.2Direct in forum Engine & Drivetrain
    Last Post: 30th October 2008, 16:14
