Thread: Wind noise from drivers side doors/ windows.
    Regular Member rosssri's Avatar
    S.Lanarkshire
    Default Wind noise from drivers side doors/ windows.
    I currently have this noise and can't seem to pin point where it's coming from as you can only hear it when driving and the mrs says she can't hear it from the passengers seat. It sounds as if theres a door or window not properly shut to me. Also when i was the car when i spray the hose over the rear window there's a tiny amount of water gets in the top corner nearest the rear end of the car.
    Has anyone else had this problem if so whats the cure?
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    not had it, do you mean the rear quarter light??
    S.Lanarkshire
    No it's either coming from the drivers door window the drivers side rear passenger window. It sounds as if the window isn't closed properly.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Can you see any ill fitting rubber or any gaps?? Does the door shut properly onto the seals?
    S.Lanarkshire
    Door shuts properly it looks like its the cushioning for the windows for the windows on the inside of the door thats causing the problem
    Jul 2006
    Mexico
    I know or I think I remember someone on here changing the door seals do to wind noise at high speeds.
    I have that issue myself...but haven't investigated much about it
    Administrator Big-Pete's Avatar
    May 2007
    Home or in the Gym
    81 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    Funny you should mention this as i've also noticed lately that mine also has a noise as if the drivers door or window aren't shut tight.. probably gonna drive me nuts when i drive to Spain, might take it to the dealers to get it looked at before i go..
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    There were some recalls on early Vec-Cs but you guys have 06 and 07 models?
    Have a look here anyway: http://forum.vectra-c.com/forumdisplay.php?f=73
    Jul 2006
    I remember Duncan saying something similar after he had his windows tinted - the problem was that the glass wasn't sitting exactly square on the guide rails that raise and lower it.
  1. Drivers side wind deflector
    By Big Knox in forum The 'Off Topic' room
    Last Post: 19th June 2012, 11:10
  2. Replies: 2
    Last Post: 4th February 2011, 21:33
  3. Noise from drivers side when turning
    By winnie2457 in forum Suspension, Wheels & Brakes
    Last Post: 3rd January 2011, 10:11
  4. strange noise from rear drivers side
    By chris_20 in forum Engine & Drivetrain
    Last Post: 27th February 2010, 21:47
