Results 1 to 10 of 11
Thread: Double DIN Nav Replacing factory ICE
    May 2008
    Swadlincote
    Default Double DIN Nav Replacing factory ICE
    I am looking at buying a 2002 Vectra C Elite to replace my 2005 SRi CDTi NAV, the elite doesn't have the factory Nav like my SRi but does have the on board computer. I am thinking (if i get the Elite) of putting in an aftermarket double din head unit / Sat Nav system as it is obviously much easier and cheaper than retro-fitting Vauxhall Nav equipment.
    What I want to know though is if I remove the factory head unit am I going to lose all functions of teh trip computer as well??
    Here, there and every where!
    Moved to this section.
    The "How 2" section is for detailed descriptions of "How 2" do a certain task on the car
    11 Post(s)
    Quote Originally Posted by p.m.adams View Post
    From what I recall of other posts, almost certainly. You won't be able to change the clock either when BST or GMT come around. For that you will have to leave the socket hanging down somewhere by the glovebox and plug in the original stereo a couple of times a year to be able to change it.
    On a Sabbatical daviek's Avatar
    ayrshire scotland
    Changed the head unit in my previous veccy and still had the use of the board computer and full control of clock settings. Best to buy the fitting kit from vauxhall .Only a single din though but worth it for the wiring loom itself and then you would need a seperate double din adaptor
    May 2008
    Swadlincote
    Any idea how much the vauxhall fitting kit is? It's for a 2002 2.2DTi with monochrome trip display.
    Regular Member lochgilp's Avatar
    argyll
    if i remember the vauxhall kit is about £38 but you can just buy the wiring loom to bring it down to normal iso for £20 and the double din kit will be £40 and you can get them all with free postage from here mate
    http://www.justkenwood.co.uk/install...del.asp?id=288
    hope that helps
    cheers
    Scott
    May 2008
    Swadlincote
    That's great. Thanks.
    Anybody got any opinions which double DIN Sat Nav / Radio system is good. I'm not looking to spend top money but something decent
    argyll
    Whats your budget mate
    May 2008
    Swadlincote
    About £500 I guess, obviously if I can get something that's good for less that would be a bonus!!!
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    http://www.caraudiodirect.co.uk/kenw...20-p-6497.html
    thats the cheapest i have found with sat nav not sure if you will get a new one with £500 perhaps try ebay for a second hand one?
  1. Replacing A NCDC 2013 Radio with a 'Normal' double DIN Headunit?
    By StreetDragster in forum Electrical & ICE (including SatNav)
    Last Post: 20th September 2013, 21:41
  2. Factory amp???
    By Jonsey in forum Electrical & ICE (including SatNav)
    Last Post: 18th January 2012, 12:43
  3. Replacing my cd30 with double din from China
    By yournicked2006 in forum Electrical & ICE (including SatNav)
    Last Post: 14th February 2011, 17:50
  4. Replacing Factory Radio - Vec C
    By BruceyB in forum Electrical & ICE (including SatNav)
    Last Post: 20th October 2010, 10:48
  5. Replacing Headunit for a Double Din HU...
    By fandango in forum Electrical & ICE (including SatNav)
    Last Post: 10th July 2009, 22:15
