Thread: help.........water!!!
    Regular Member lilangel's Avatar
    bucks
    Default help.........water!!!
    i ve got very soaked floor in both front and rear passenger footwel! have cracked screen, could that be the reason? checked the pollen filter and nothing there..........................help please!!!!
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    none of the side windows whore down by any chance as its the front and rear
    or a door seal
    Feb 2006
    Guttedsville
    Sounds like the drain in the pollen filter area is blocked, check that first.
    Here, there and every where!
    Is the drain from under the pollen filter clear? It gets blocked and water gets through to the passenger side
    The crack in the screen will only be on the outside probably (laminated) so the inside will be intact.
    bucks
    thnx, will have a look better tomorrow, only checked to see if there was summin there but didnt see anythin...its well soaked! can it do any damage?
    Full Member Big Sig's Avatar
    Quote Originally Posted by Caterman View Post
    When mine leaked the lamination seal went on the passenger side, the drain was fine.
    Regular Member Stuarty's Avatar
    Aberdeenshire
    The same happend to me years ago on my first car albeit it was a citroen ax gt but it turned out to be the heater matrix that was leaking hth.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Make sure that you dry the car completely. Otherwise you will get odours and possibly more issues from corrosion and carpet rot etc...
    I would look at the drain under the pollen filter first, as it's easy to check and clean out.
    bucks
    well it was a bloked drain, so hopefully it wont repeat, in the process of dryin it at the moment.... thnx.!!!
  1. water water everywhere
    By rob warrington in forum The 'Off Topic' room
    Last Post: 9th December 2012, 00:03
  2. water and oil
    By Tinks in forum Engine & Drivetrain
    Last Post: 16th February 2012, 19:40
  3. What colour is your radiator water bottle water? and head gasket.
    By Jow20 in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2011, 21:39
  4. oil in the water (PLEASE HELP)
    By steve.davies in forum Vectra C / Signum Car Chat
    Last Post: 11th February 2007, 23:17
  5. Water water everywhere!
    By Big Sig in forum Vectra C / Signum Car Chat
    Last Post: 7th January 2007, 15:09
