Thread: need advice asap
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    Default need advice asap
    will facelift zenon headlights still work with pre-facelift loom and whats the difference between standard and zenon
    as i could be getting some tomorrow
    many thanks
    Regular Member 3.2_V6_VXR's Avatar
    S.Wales, Nr Swansea
    personally m8, i would get normal facelift headlamps and fit a good quality xenon conversion kit into it
    S.Wales, Nr Swansea
    otherwise ul be doing a bit of cutting to match them in
    Quote Originally Posted by 3.2_V6_VXR View Post
    cutting what m8 as i dont know much about zenon lights
    Basically, unless they're factory installed from manufacture, aftermarket kits are the only way to go. They have their own legality issues however...
    S.Wales, Nr Swansea
    the xenon headlamps have different connectors to the standard headlamps mate, i would defo recommend a conversion kit in standard headlamps, that way you can still control the up and down movement of the lamps from in the car, if you go the xenon route you would have to wire in the self levellers etc
    to much work
    the xenon headlamps have different connectors to the standard headlamps mate, i would defo recommend a conversion kit in standard headlamps, that way you can still controll the up and down movement of the lamps from in the car, if you go the xenon route you would have to wire in the self levellers etc
    to much work
    thanks for the advise fella most appreciated
  1. Need advice ASAP
    By roverjay in forum Troubleshooting
    Last Post: 21st August 2012, 11:23
  2. Ladies advice needed ASAP
    By Mrs K in forum Electrical & ICE (including SatNav)
    Last Post: 8th July 2011, 11:33
  3. Bit of advice regards to mpg screen asap
    By Devvo SRI CDTI in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2011, 22:55
  4. Need help/advice asap! Grille badge!
    By paul_sri150 in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2011, 22:44
  5. advice asap on egr valve
    Last Post: 27th February 2010, 11:30
