Page 1 of 6 123 ... LastLast
Results 1 to 10 of 53
Thread: AC compressor
    Regular Member Dave1.8's Avatar
    Oct 2007
    Ellesmere Port
    Default AC compressor
    I have a slight whirring noise from my AC compressor (I think). I can only hear it when I'm stationry and I rev it slightly, I can't hear any noise when I'm on the move or on tick over. And the noise goes away when I disable the AC. Has anyone else noticed this? thanks Dave
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    Needs re-gassed. The gas acts as a lubricate so if its low you can get a slight noise.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    If the gas pressure is too low, the AC won't engage though. Does the AC actually work like a fridge?
    Oct 2007
    Ellesmere Port
    Quote Originally Posted by John35 View Post
    Thanks, should I stop using it til I get it re-gassed?
    Oct 2007
    Ellesmere Port
    Quote Originally Posted by Ste View Post
    Not sure, this is my first car with AC that works, but it does get cold
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Rephrase, does it get very cold when it's on?
    Oct 2007
    Ellesmere Port
    I can hear the compressor kick in, and the air gets a lot colder. I'm not sure if its as cold as it should be?
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    What John says is quite correct, there is a lubricant in with the gas. BUT if it's working well it suggests there is enough gas in it.
    Does the noise disappear after a while, or does it continue ad infinitum?
    Oct 2007
    Ellesmere Port
    The noise stays the same all the time ad infinitum. When you suggested WD40 Ste, I went out and sprayed a bit on the compressor, and it did seem to get less noisy.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    How much less noise, a lot, a little, 33% less????
  1. Air Con Compressor
    By Siggy08 in forum Vectra C / Signum Car Chat
    Last Post: 28th November 2012, 15:52
  2. Air con compressor
    By keith1983 in forum Electrical & ICE (including SatNav)
    Last Post: 28th November 2009, 19:20
  3. air compressor
    Last Post: 18th November 2009, 07:56
