Results 1 to 10 of 15
Thread: Parking Sensor Dealer Fit
    May 2008
    Worcester
    Default Parking Sensor Dealer Fit
    Hi Guy's,
    I need a rear parking sensor set up for my Vectra Estate, with all the fishinbg kit in it I can see a thing.
    My local stealer has quoted £180 for a Meta System Active Park 4 product with 4 sensors and colour matched (rear only)...
    Anyone used this make?
    I'm waiting for another quote for a cobra system again anyone used one of these systems, auto express weren't to kind about them
    All other suggestions greatly received - Worcester area
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    how about 25£ and use 1-2 houres doing it your selv (make a seach and you will see)
    May 2008
    Worcester
    it's just the thought of taking the bumper off and routing the cable... the electrics aren't a problem
    Engine : 2.2 Direct
    well i have a estate, and are NOT planing to take of the bumper to fit the parkingsensors.
    May 2008
    Worcester
    i've not had a look underneath the car far to wet here in the UK at present. Do you think it's p[ossible to fit the sensors without the removal of the bumper?
    Engine : 2.2 Direct
    yes its posible (if you lift the rear end)
    (just checked) im not planing to take mine off.. remember the sensors go to the black trim (buttom) not the painted parts.. if bumper is clean inside and with light you should be able to se where the sensores should be fitted.
    May 2008
    Worcester
    cheers kenp, just assumed the sensor's would be fitted to the coloured section of the bumper and not the black trim...
    That would make the kit selection a lot easier!
    Engine : 2.2 Direct
    yes on all the others they are in the coloured section.. but not the estate (dont know why)
    May 2007
    Dartford
    I did mine without removing the bumper, and I put them on the coloured plastic bit rather than the black part (I didnt like them on there)
    May 2008
    Worcester
    tempo, what did you use to secure the cables to the back of the bumper, before feeding them inside the car?
  1. Help with OEM parking sensor
    By andreitone in forum Electrical & ICE (including SatNav)
    Last Post: 10th June 2009, 09:55
  2. Dealer Fit Parking Sensors
    By um20 in forum Vectra C / Signum Car Chat
    Last Post: 27th March 2007, 17:45
  3. Thinking of getting Parking Sensors from VX Dealer
    By doncaster_mainline in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2006, 00:39
