Thread: All dials to zero; ABS & battery lights on; engine runs fine...
    Essex
    Default All dials to zero; ABS & battery lights on; engine runs fine...
    Hi all
    Couple of times recently I've had all the speedo / RPM / Battery Charge dials drop to zero, whilst at the same time the Battery charge light + ABS + anti skid lights have all come on.
    This has happened about 4 times in the last week; (twice on two journeys).
    Both times roads were wet / raining, and both times I had the headlights on (although I've also driven in the wet with lights on and this hasn't happened...)
    All this happens whilst driving; the engine continues with no problem though, and the headlights stay on.
    Nothing shows in the computer display (ie no spanner), and if I stop the engine, it restarts with no problem and with everything back to normal again.
    Any ideas?
    2003 Vectra LS 16V
    Ian in Essex
    Regular Member garvey's Avatar
    Co Durham
    do a search for abs plug, common problem
    Full Member Big Sig's Avatar
    My first guess would be the CIM on the steering coloumn. If it is they are best part of £400 Hopefully someone else will be along in a min with some more suggestions
    Co Durham
    try unplugging and plugging back in check if clean i used suffer same problem but not since
    Essex
    Was searching for ABS plug threads...
    You're a star for the picture garvey as I ain't too hot under the bonnet...
    I'll try that tonight
    Ian
    Jul 2006
    Mexico
    As above....first try with the ABS plug...no money involved...if problem persist that will be the CIM then.....money involved in that case.
    HTH.
  1. Signum dashboard lights and dials not working
    By sjmiow61 in forum Electrical & ICE (including SatNav)
    Last Post: 13th September 2010, 22:32
  2. Replies: 2
    Last Post: 29th January 2010, 11:51
  3. clocks dials battery abs fault engine sputtering
    By deano7781 in forum Introduce yourself.
    Last Post: 30th November 2009, 23:28
  4. Instrument Panel dials lit when external lights off
    By Street N in forum Electrical & ICE (including SatNav)
    Last Post: 15th January 2009, 23:26
  5. Replies: 3
    Last Post: 7th August 2007, 18:55
vectra c battery light abs light clocks
