Thread: Handbrake warning light
    West
    confused Handbrake warning light
    The warning light came on this morning, (whilst driving) without the handbrake being applied...
    Is this a warning for the clutch/brake fluid level or do i need to investigate the switch?
    I havent had time to check any levels (today) as yet, just wanted an opinion.
    Cheers!
    Regular Member fields's Avatar
    Mar 2007
    Lincoln
    Don't really know on the Vec but on all other cars I,ve had it doubles as a low brake fluid warning too.
    West
    Any one? ? ?
    Jul 2006
    Mexico
    First check fluid level ASAP, if that is OK might be a faulty sensor, or a problem with ABS system.
    Try to check the fluid ASAP (again) not save to drive without good working brakes
    HTH.
    West
    I have just checked the fluid reservoir & the fluid is on the lowest level marker, so hopefully a top up might cure it.
    Jul 2006
    Mexico
    I think that will do
    Keep us posted mate
    11 Post(s)
    Why was it low in the first place? Have you checked for leaks?
    West
    To be honest, i think the fluid is low due to...
    Rear calipers were changed & just after they were changed one of them was faulty & yes i lost some fluid over the driveway.
    The motor was driven to my mates garage with the faulty caliper clamped off as it was leaking,
    the caliper was replaced as it was a new part & under warranty, i don't know if the level was topped back up or not.
    However:
    Update, i had the warning light come back on this morning & after topping up the reservoir just now the light has gone out & stayed out.
    Quick road test with some heavy braking, abs working as it should & fluid level is still at maximum.
    Cheers!
  1. Handbrake light on when its off!
    By SlowCoach in forum Suspension, Wheels & Brakes
    Last Post: 30th January 2013, 10:46
  2. handbrake light problem
    By callum in forum Vectra C / Signum Car Chat
    Last Post: 13th November 2011, 22:55
  3. Handbrake Light / Switch
    By si_hoss in forum Suspension, Wheels & Brakes
    Last Post: 15th February 2011, 11:42
  4. Warning !!!! Handbrake Fault!!!!!
    By chelskilee in forum Vectra C / Signum Car Chat
    Last Post: 26th September 2007, 11:04
  5. Handbrake warning from vx
    By :LeeR: in forum Vectra C / Signum Car Chat
    Last Post: 24th September 2007, 21:37
vectra c handbrake warning light faulty
