Results 1 to 10 of 15
Thread: Washers not washing!!
    Northampton
    Default Washers not washing!!
    Hi guys hope you can help.
    The windscreen washers on my '03 Signum (fr and rr) are not working checked the obvious (fluid) , and the motors can be heard but at best all you get is a dribble. This leads me to think there must be a blockage some where.... but where?
    Help!!!! at this time of year this is the last thing you need.
    Cheers.
    Regular Member ion's Avatar
    walsall
    Silly question, but it's not frozen in the pipe is it?
    Northampton
    Don't think so although we've had a hard frost today the problem occured yesterday in the afternoon and I have been using almost neat fluid.
    Regular Member david-bell's Avatar
    eastlothian scotland
    Vehicle : vectra vxr
    Trim : vxr
    Engine : 2.8 v6 turbo
    Mileage : 31000
    hi mate i had this prob .with mine it was gunge that had built up in the bottom of the resivoir just where the motor sucks the water up it had chocked the pipe hence my front washers didnt work but my rear was fine gave it clean been fine ever since
    Northampton
    How and where?
    Trim : vxr
    Mileage : 31000
    if you have a look under the front left wheel arch/ bumper you will see the washer bottle im sure on the inner side of the bottle yuou will see the motor pull the motor out just held in with a rubber seal. in the bottem of the motor mines was full of **** quick clean its been fine since also i found it easer to undo a few of the torx screws that hold the inner arch linning pull the arch linning back you can get in there a bit easier hope this helps
    Northampton
    Thanks I'll give it a go. Always easier to ask than go blindly pulling the car apart.
    Cheers David
    Dec 2005
    RUNCORN
    my mate went to vx with the same problem on a 04 and they told him there was a £68 charge to find out the problem if it was the motors he would not be charged as they are under warrenty but if its gunk the charge will stand how **** is that for service times like that i am sorry i got a vec
    Northampton
    That's why these forums are invaluable, I'm competant enough to do jobs like this but my wife would have just taken it to the nearest Vaux dealer and before you know where you are your looking at the thick end of heafty bill for something very trivial.
    That is if it is only a blockage.
    Regular Member cpt slow's Avatar
    In a house
    I had exactly the same problem , took off wheel arch liner slightly and sure enough there was a blockage on one of the plastic joints . When refitting dont do what i did , reversed the pipe conection pulled on wiper stalk and the rear squirted pushed on stalk and front squirted. LOL . Best of luck !
  1. Washing
    By Redviper in forum Vectra C / Signum Car Chat
    Last Post: 23rd October 2009, 12:09
  2. washing car with washing liquid
    By gallag in forum Vectra C / Signum Car Chat
    Last Post: 13th July 2008, 16:34
  3. washing your car
    By steve.s in forum Vectra C / Signum Car Chat
    Last Post: 8th June 2007, 15:57
  4. Washing a new car.
    By baard in forum Vectra C / Signum Car Chat
    Last Post: 10th December 2006, 18:44
