Thread: Help 2.2 Direct Stuttering under hard acceleration
    Newcastle Upon Tyne
    StatsVehicle Info
    rolleyes Help 2.2 Direct Stuttering under hard acceleration
    Can any one offer some advice whan accelerating hard in any gear once the revs reach 3000rpm the car seems to falter as if there is not enough fuel getting through then once it passes this 4000 rpm stage it seems to pick up again but with the warning light coming on and staying on until the car is switched off and back on again.
    It runs fine with a light load and gentle acceleration but that is no fun.
    The car has covered only 33500 miles and is on a O5 plate I do not have a fault code reader the dealership who I bought the car off with an extended year warranty has just told me to bring it in for a 45.00 quid diagnostic check and that I'm not covered for electrical problems.
    Not sure if this is relevant but the car stinks on warmer days like the Cat was damaged and the exhaust makes a fluttering noise could the 2 problems be related as a lack of back pressure might make the fuelling map change ???? only a guess.
    StatsVehicle Info
    hmm... you bought it from a dealers.. VX Dealers?.. and was the warranty a NetworkQ one?
    if it is a NetworkQ warranty then you ARE covered for electrical faults..
    the £45 charge is a standard 1/2 hrs fee, just to get an initail diagnosis.. many dealers charge this as if the fault isn't covered under warranty VX won't pay for any diagnosis time..
    for accurate diagnosis, it will really have to go and get plugged in. we can guess from afar based on previous experience but for 100% certainty we need the codes it has stored..
    Newcastle Upon Tyne
    StatsVehicle Info
    Default More information
    Thank you for the help so far, I will post the fault codes after the diagnostic check tomorrow.
    The Garage was not a NetworkQ dealer which at the time I did not think would be important low mileage fairly new car etc
    North West & North Wales Assistant Regional Organiser Drinky's Avatar
    StatsVehicle Info
    Sounds like one of the fuel pumps to me !!!!!
    Regular Member benny's Avatar
    Feb 2006
    dudley
    StatsVehicle Info
    will be the high presh fuel pump and the fuel presh regulator also will need a pipe from the pump to the rail very common on the dirrects
    Regular Member sparky71a's Avatar
    Apr 2006
    At the Garage
    StatsVehicle Info
    Quote Originally Posted by Geordie2.2 View Post
    The last three letters on your reg,aren't MOF are they?
    Newcastle Upon Tyne
    StatsVehicle Info
    Default Permanant Solution to this problem
    Is there a permant fix or known solution to this problem as once the car is out of warranty it could start to be expensive.
    Hopefully this will be classed as a mechanical failure rather than an electrical fault as this is what the warranty will cover hopefully
    Hello Sparky71A the last 3 digits are KNJ.
    Apr 2006
    At the Garage
    StatsVehicle Info
    phew thought you'd bought me old motor then,i would have gone for damaged cat if that had been the case,as they took ages to replace the oxy sensor.
    Newcastle Upon Tyne
    StatsVehicle Info
    Default Update on the problem
    Sorry for the delay in getting back with more information, but the garage has just informed me that the problem with the car is the Inlet Manifold Swirl sensor have seen the posts for the CDTI but is it the same for the 2.2 direct petrol.
    The good news!!! is that the parts and work required are covered under the warranty but it will be a full day job.
    Do's this sound right.
    Regular Member KC's Avatar
    Dec 2005
    West Lothian
    StatsVehicle Info
    Sounds correct to me. I have had two swirl valves worked on in the short time I have had my 2.2 direct.
  1. Smoke on hard acceleration
    By Derek Mc in forum Diesel Engine related
    Last Post: 28th February 2014, 22:45
  2. 2.2 Direct Petrol unstable acceleration
    By paul1779 in forum Troubleshooting
    Last Post: 13th April 2013, 09:33
  3. Replies: 10
    Last Post: 6th February 2010, 15:00
  4. Whistle during hard acceleration
    By TheWildHaggis in forum Vectra C / Signum Car Chat
    Last Post: 1st July 2009, 11:05
  5. 'Hard' Acceleration
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 22nd September 2008, 11:48
vauxhall vectra 2.2 direct sputters when accelerate
vauxhall vectra stuttering
when accelerate vauxhall vectrs car stutters
vauxhall vectra stutters on exceleration
