Thread: Missing Boot Lights?
    May 2008
    Berks
    confused Missing Boot Lights?
    Hello (my first post!)
    I've recently brought a 05 plate sri cdti (150), and there are no boot lights :-(
    I see on the sides, (eg above the first aid box) are 3 rectangular cut out holes on each side that look like any boot lights should be in there, but they are just holes.
    Is this normal? Can boot lights be fitted?
    Thanks!
    they are vent holes.. the boot light is normally located in the left hand boot liner, just to the rear of the side pocket, right up behind the tailight cluster...there should be a white rectangular light fitting...
    usually the wiring is off the back of the unit or the bulb has fell out of it's contact..
    May 2008
    Berks
    Golly, dunno how I missed that! It's there, and was missing a bulb! All working now!
    Thankyou.
    Birmingham
    Thank god for that, I was going to rush out to mine and see if that was one of a long list of things that Vx are trying to save money on! PHEW!
    Check out this thread.....the missing list seems to be increasing! LOL>
    Bye bye Vec B
    - Hello Siggy!
    Regular Member carpet's Avatar
    Jul 2006
    TENTERDEN KENT
    This missing boot lamp is down to the dealers (mainly use car). It is removed so that when the cars are on display with the hatch open the bulb does not drain down the battery!!! They must have a fair few of them by now.
    Birmingham
    something else I noticed missing from my car.....30 bhp !!!!!!!!
    LOL.
    Bye bye Vec B
    - Hello Siggy!
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    Quote Originally Posted by carpet View Post
    Trouble is the dealer doesn't read the manual,the vec turns the lights off itself to save battery drain.
    11 Post(s)
    Quote Originally Posted by tyreman View Post
    Trouble is, not all Vauxhalls do it, and trying to remember which ones do and which ones don't - along with all the other makes and models on the forecourt as well, its just easier to pull the wires out on all of them and be done with it.
    May 2008
    Berks
    What doesn't make sense is that I brought the car from a private seller. He must have had no boot lights since he brought it froma dealer years ago! ;-)
    Thanks again for the help guys!
    Birmingham
    as you go around your car, you will start to notice things that others have that you dont! its quite pathetic as they are "normal" things you would assume are standard!
    Bye bye Vec B
    - Hello Siggy!
  1. Lights, Wipers, Boot.
    By tgarrett in forum Electrical & ICE (including SatNav)
    Last Post: 26th December 2011, 10:12
  2. Additional Lights in Boot - WEIRD problem
    By NealM in forum Electrical & ICE (including SatNav)
    Last Post: 14th March 2011, 13:03
  3. How can i turn my boot lights off
    By Pjuk in forum Vectra C / Signum Car Chat
    Last Post: 18th March 2009, 11:04
  4. Missing fog lights...
    By Fatbloke in forum Vectra C / Signum Car Chat
    Last Post: 26th February 2008, 16:57
  5. Boot rattle. Parts missing
    Last Post: 21st August 2006, 07:11
vectra c boot light draining battery
