Thread: Knocking On Drivers Side
    Regular Member nufckev's Avatar
    May 2008
    NEWCASTLE
    Default Knocking On Drivers Side
    IVE GOT A KNOCK IT SEEMS TO COMING FROM DRIVERS SIDE WHEEL AREA, ONLY DOES IT OVER SPEED BUMPS OR ROADS THAT ARE A LITTLE BIT UNEVEN,ONLY HAD THE CAR A FEW WEEKS SO HAVENT HAD A CHANCE TO HAVE A PROPER LOOK AROUND ANY HELP WOULD BE MOST WELCOME
    THANKS
    scotland
    most likely the drop link mate
    not hard to replace
    May 2008
    NEWCASTLE
    Default front end knock
    hi how do i change them and what is the cost of them sorry to be a pain but i aint don much work on vectras but just learning and i must say great site
    they are really easy.. all you'll need is a 17mm spanner and an 18mm socket..
    jack and support the car on a stand, remove roadwheel..
    undo either end of the bolt on the link.. the spanner goes behind the plate/bar onto two flats on the balljoints shaft ( have a look on the new one to see) to stop it turning as you undo the nut..time to do it?...15 mins a side tops..
    parts are avaliable from ebay for £12 upwards..unless you have a really 'trick' car with IDS then one size fits all..
    Chester
    Regular Member m_r_shaw's Avatar
    Sunny Waterloo, just outside Liverpool.....
  1. knocking on drivers side solved
    By baz2003uk in forum Vectra C / Signum Car Chat
    Last Post: 28th August 2012, 20:38
  2. Knocking Sound From Drivers Front Wheel
    By corderz in forum Suspension, Wheels & Brakes
    Last Post: 11th March 2011, 03:10
  3. Cluncking/knocking from rear drivers side.
    By deeks in forum Suspension, Wheels & Brakes
    Last Post: 8th March 2011, 11:11
  4. Knocking from Drivers side front
    By sxi-dean in forum Suspension, Wheels & Brakes
    Last Post: 21st February 2011, 16:18
  5. kNOCKING ON DRIVERS SIDE??
    By Si-SRI in forum Vectra C / Signum Car Chat
    Last Post: 18th December 2009, 20:40
