Results 1 to 2 of 2
Thread: Parking Sensor Warning Light/Message
    Regular Member marcdale's Avatar
    May 2006
    Bristol
    Default Parking Sensor Warning Light/Message
    Hi,
    I started getting a warning message on the onboard computer regarding parking sensors the other day. It happens every time I try to use them. The systems tries to start up as normal every time I go in to reverse, but the warning light on the dash comes on flashing, and then after maybe 15 to 20 seconds the warning light on the dash stops flashing and displays constantly and at the same time I get a continuous error tone.
    I appreciate this means there is a fault, but I wondered if there was any easy checks I can do to find out if it's the control module, or if it's the front or rear sensors for example? it would be nice to think that because the error tone is from the rear that it means the rear sensors were bust? Is it that logical?
    Can I purchase individual sensors?
    Any other suggestions would be great. They are the factory fitted items on a '04 GSi. Control unit on side of circuit board in boot etc....
    Thanks in advance.
    yep, sounds like the rear sensors..
    have you tried the battery disconnect.. normally sorts out errant controllers....very unusual to have to replace the sensors themselves..
  1. parking light warning but no bulbs out
    By forde in forum Electrical & ICE (including SatNav)
    Last Post: 6th February 2013, 14:21
  2. front right parking light warning
    By rfc52 in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2013, 13:05
  3. Parking sensor light warning on.
    By nelly452 in forum Electrical & ICE (including SatNav)
    Last Post: 8th December 2011, 01:56
  4. Brake light warning message on display
    By don1966 in forum Electrical & ICE (including SatNav)
    Last Post: 1st December 2011, 11:15
  5. Brake light warning message
    By babilon2 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd September 2011, 16:03
vectra c parking sensor light flashing
Vauxhall parking sensor warning light
parking sensor light flashing signum
