Results 1 to 3 of 3
Thread: Amplifier on oem DVD90
    May 2008
    brussels
    Default Amplifier on oem DVD90
    Hi,
    I'm would like to put in an amplifier with subwoofer in my vecta with DVD90.
    I went to the dealer butt nobody there could help me.
    Does anybody have any idea how to do it???
    thank you
    WhiteC
    Administrator plasma's Avatar
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    You'll need to find someone who is knowledgeable with car audio installs but basically they'll need to tap into the rear speak outputs and put a high level to RCA converter in, then run 2 x rca's to the rear (or whereever you want the amp), also you'll need a local ground/negative (someone people like to run a seperate negative direct from the battery) plus a fused (near the battery) cable down to the rear as well. Amplifer will connect to these cables you've run.
    Oh and also a switched live to turn the amp on but not sure where this can get gotten from? maybe the cigar lighter i'm thinking. Someone in the car audio business car advise you what size and types of cables you'll need..
    Actually. think someone on here has already done a subwoofer install into the little hatch near the rear lights. i'll see if i can find it..
    http://forum.vectra-c.com/showthread.php?t=15590 (not the one i was looking for but a good one nethertheless)
    And other people swear by using line drivers too. Similar to a Hi-level to RCA converter but allows you to process and clean up the signals coming from the headunit (RCA converters about £5-£15 whereas line drivers can be £60-£300 or more!) depends what type and quality of sound your looking for.
    May 2008
    brussels
    Ok so it's only possible by taking the rear outputs and convert them.
    Will the rear speakers stil work?
    I've found on the web that there is something called mini din that converts to RCa's, butt I don't have much info about that... and I don't know if I can use that on the DVD90
    I have a lot of pins that are not used on the radio do somebody have the cable plans for this radio?
  1. amplifier and fan to suboffer
    By Manuel R.B.B in forum Styling
    Last Post: 4th August 2009, 16:02
  2. Aerial Amplifier
    By lizard in forum Electrical & ICE (including SatNav)
    Last Post: 31st July 2009, 10:07
  3. Amplifier Rating
    By siz1 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd December 2008, 10:46
  4. sub and amplifier
    By vectragsi3.2 in forum Electrical & ICE (including SatNav)
    Last Post: 7th April 2008, 22:48
amplifier dvd90
