Results 1 to 10 of 11
Thread: Yellow residue on brake discs !!
    May 2008
    SE london
    Default Yellow residue on brake discs !!
    It's been tipping down in SE London all day. Which i think has a large bearing on my question.
    I noticed this morning that on all 4 brake discs that there was a some noticeable yellow marks which I had not seen before. I ran my finger over one of the discs and was left with the same yellow stuff on my finger tip.
    I then drove a shortish distance using the brakes normally (with nothing unusual to report). After the short drive I re-checked the discs and the looked perfectly normal with the yellow stuff gone !!
    Can anyone tell me how normal/abnormal this might be and if abnormal what the issue is ?
    Car is due into my local VX dealer on Wednesday for some issues to be looked at, including rear brake stuff. Would like to be able to know whether this "yellow" thing needs mentioning !!
    Cheers in advance
    member of the smoke patrol 230bhp+
    could just be rust marks on the disc's if its the rust marks that's normal
    Full Member Big Sig's Avatar
    Normal, its called "rust" or "Oxidation". Caused by water etc. Nothing to worry about mate
    May 2008
    SE london
    Cheers guys.
    But why would the rust only appear when wet ?
    would it not be visible all the time ?
    Basically because the water speeds up the oxidation process.
    it will appear a lot faster in the wet or the damp
    today would be a good day to look at other cars around yours and look at there disc's are the same as yours have gone
    Belfast
    Are you for real, or are you extracting the urine?
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    Quote Originally Posted by _ZS_ View Post
    just what i was thinking!!!! i thought that was common knowledge
    May 2008
    SE london
    Quote Originally Posted by vectragsi3.2 View Post
    Yeah, Iím for real. Iím well aware of what rust looks like.
    The reason I asked the question is that rust in my experience is dark red/orange and the stuff on me fingers was bright yellow !
    Still thanks for taking the time to post.
    Regular Member GoldenWonder's Avatar
    Durham
    Wash your car with a hose, and then look at the disks an hour or two later, they can be coated with yellow residue that quickly!
  1. yellow stuff brake pads question.
    By rozzer2006 in forum Handling & Braking
    Last Post: 13th November 2012, 23:40
  2. Yellow brake disks....
    By Rorschach in forum The 'Off Topic' room
    Last Post: 10th June 2011, 11:30
  3. yellow brake calliper brake set
    By The Gas Man in forum Parts for sale
    Last Post: 22nd July 2010, 22:41
  4. yellow brake callipers
    By The Gas Man in forum Vectra C / Signum Car Chat
    Last Post: 30th June 2010, 23:05
  5. What brake pads for 2.8 V6 Signum??? 314mm brake discs
    By luke4487 in forum Suspension, Wheels & Brakes
    Last Post: 25th February 2010, 23:21
insignia yellow brake disc
yellow brake discs
