Thread: Front mudgaurds...
    Dec 2005
    Bristol
    Default Front mudgaurds...
    Forgive me for being thick, thought I was reasonably intelligent, but I can't make sense of the destructions for fitting the front mudgaurds!.........anyone fitted these? The pic's that accompany the bits are a little vague
    Duncan.
    yep they are a bit vague!!
    from memory now you have got a torx screw that screws into the clip supplied on the underside of the side skirt that is the first fixing point (if you offer the mudflap up you will see where it goes )then you drill a 7mm/8mm hole into the arch liner and fit mudflap with plastic rivet supplied.
    i hope thats a little bit helpfull
    Dec 2005
    Bristol
    Quote Originally Posted by vectra 2.0 t
    Yep, very helpful.......couldn't see where the rivets were used, makes more sense now, cheers!
    Jan 2006
    Dalriada
    i fitted front and back mudflaps on my car today, took around half and hour. My kit never came with the relevant fittings ie rivets and screws so i went to my work and got self tapping screws and bolts for underneath. eveything works fine with self tappers and the bolts for the front flaps so might be an idea jsut to use this method if your struggling..
    Dec 2005
    Bristol
    Thanks for the reply, but I reckon the fitting will be easier now, just couldn't see in the pic/instructions where rivets went....know now!
    Regular Member bobbyboy's Avatar
    Jan 2006
    Durham...
    I got some yesterday...looked at the instructions...and thought...
    maybe tomorrow,
    or the day after, or the one after that........
  1. Replies: 6
    Last Post: 14th April 2008, 22:02
