Thread: Vectra Design - 2 questions!
    May 2008
    High Wycombe
    Default Vectra Design - 2 questions!
    Hi
    I have 2 questions if anyone knows the answer. In process of buying a 07 design.
    1. When i test drove the car it seemed that i could not activate the cruise control until i was over 50mph (this is the explanation from the seller) but in the manual it states it can be activated from 20mph. Is there any other reason why i may have not been able to activate it?
    2. The activation button so that the alarm does not monitor the passanger compartment did not seem to come on when i pressed it. Is there a specific way to turn this on?
    The garage is now closed and these are my only 2 concerns. Rather than wait until tomorrow to ring the garage was wondering if anyone could advise.
    Many thanks
    Matt
    Regular Member 2.2direct-sri's Avatar
    Aug 2007
    Aberdeen
    Cruise control should come on after you hit 20mph. Will only do it after having pressed the brake pedal after starting off (safety feature).
    The activation light will come on but only when you open drivers door.
    Full Member Big Sig's Avatar
    You should have to use the brake before it will come on, 20mphish is where mine works from. I think the alarm button just flashes once when you push it. Not 100% sure. But if it doesn't work then its still under the VX warranty anyway.
    May 2008
    High Wycombe
    Think i will get the garage to check it out before i pick it up!
    Mileage : 000
    The alarm if I am correct when you press it, it dissables the sensor for inside the car, and only works once "ie" when you open the door it reverts back to being re-armed inside the car.
    you need to do it each time you intend to alarm the car.
    May 2008
    High Wycombe
    But if you are sat in the car with the doors shut and you push the button then it should light up or blink! Right?
    Yeah, I think it should flash
    Here, there and every where!
    Quote Originally Posted by n33712 View Post
    Just tried mine and it does light up whether the door is open or not Disarms as soon as the doors are unlocked. HTH.
    May 2008
    High Wycombe
    Okay cheers all. Give the garage a call tomorrow.
  1. Our New Vectra Design
    By Ross-SRi in forum Quick Photo Album
    Last Post: 16th October 2009, 07:06
  2. My 06 Vectra Design
    By GlennM in forum Quick Photo Album
    Last Post: 5th August 2008, 12:22
  3. Siggy Design questions
    By Trick202 in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2008, 17:51
  4. 06 1.8VVT Design - pre-purchase questions.
    By _ZS_ in forum Vectra C / Signum Car Chat
    Last Post: 27th June 2007, 22:31
  5. Vectra Design 1.8
    By Tim2100 in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2007, 03:51
