Results 1 to 2 of 2
Thread: Misfire - even at idle when hot
    Regular Member muctm's Avatar
    Mar 2007
    on the milky way
    Default Misfire - even at idle when hot
    I have a 1.9 CDTI (150) 2004 model, 30000 miles. I have the problem with the intake swirl valves, the rod is very worn out...so it doesn't stay on for too long so I took it out and set the valves for open position (better performance on the highway), I don't have the money for the new inlet right now... The EGR is very ok (folowed the cleaning how 2 on the forum)...
    Now the simptoms: misfires at idel even when hot...and the instant fuel consuption rises for a sec when it happens. If I try to acc hard it in traffic, I get a misfire first and then the car accelerates...
    Is it the loom problem? or something else...
    PS: no warning lights on the dash.
    Mar 2007
    on the milky way
    All fixed after changing the inlet manifold...AND cleaning all the bits that are attached to it.
  1. Misfire at idle
    By mechman458 in forum Engine & Drivetrain
    Last Post: 12th March 2012, 14:13
  2. Vectra C 1.8 SRi Misfire when idle? HELP PLEASE?
    By shaine415 in forum Engine & Drivetrain
    Last Post: 25th February 2012, 15:52
  3. Slight misfire at idle
    By Lozza in forum Vectra C / Signum Troubleshooting
    Last Post: 17th June 2011, 06:52
  4. 2.0 turbo vectra low idle maybe misfire??????
    By vectra100turbo in forum Engine & Drivetrain
    Last Post: 1st February 2011, 17:36
  5. misfire at idle
    By billroy in forum Engine & Drivetrain
    Last Post: 14th November 2010, 01:11
