Results 1 to 10 of 11
Thread: help please! on 1.8 vvt 06 engine - plugs
    Regular Member PeterVV's Avatar
    Oct 2007
    south wales
    Question help please! on 1.8 vvt 06 engine - plugs
    just servicing my car, oil draining as I type! got a set of plugs but cant see where to start.
    There is a plastic strip with the ECO writing on it with two bolts holding another strip underneath, is that where they are hiding?, or there is a Metal bar behind the plastic carbunkle, also held on by two torx bolts, which has a lit of gubbins in the way and connectors on it ?
    HELP PLEASE I would like to finisgh the job!
    cambs
    the covers comes of then the other thing is the coil pack
    just undo it and pull up carefully then the plugs are underneath
    Oct 2007
    south wales
    Quote Originally Posted by mhvcbv View Post
    bit more info please? what covers & how? - the coil pack ? is that attched to the metal bar at the back of the plastic
    sorry to be so thick, used to old engines...
    cambs
    its hard to descibe but you remove all you see on the top of the engine were the plugs are untill you get to the coil pack which goes on all 4 plugs(its 1 complete unit) undo and lift up carefully then you get to the plugs
    hope this helps
    Oct 2007
    south wales
    hope this helps
    thats just it I dont realy know where they are! looks as though the bar holds the coil pack which disaperas under a plastic strip which looks as though it has loads of little clips holding it on, dont want to risk snapping any off if no need?
    Oct 2007
    south wales
    Default wont someone think of the children!
    Sorry bout that , now I have your attention, can you help me with my plugs!!!!
    Aberdeen
    Not done this myself yet but from what i have figured out, Is it not a matter of slidding off the engne cover? Looking at the top of the engine, their is a indented line that runs from a bout a tird of the way down on the right to two thirds of the way down in a u shape going left. I think this cover slides off to the right and the plugs are under their.
    Hope this makes sense.
    Oct 2007
    south wales
    confused
    Quote Originally Posted by TheWildHaggis View Post
    Trouble is there are two covers in the big plastic carbunkle, the top one near the bar that covers the coil pack, has loads of little plastic clips all the way around, and I dont want to break any if theres no need, the second one with the words ecotec on it comes off to reveal two long torx bolt which probably hold the whole carbunkle on, so dont think it all needs to come...........
    got and pics????
    Oct 2007
    south wales
    not yet, wife uses the car to go to work, so dont have much chance, which is why I changed the oil on bank holiday Monday ( in a puddle!)
  1. 1.9 cdti Z19DT estate engine juddering plus white smoke coming from engine bay
    By danedragger in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2013, 17:44
  2. Replies: 0
    Last Post: 24th January 2013, 18:50
  3. Changing Plugs, Hot or cold engine?
    By PeterVV in forum Engine & Drivetrain
    Last Post: 18th June 2012, 23:37
  4. What are these plugs for (front of engine bay)
    By Thom in forum Engine & Drivetrain
    Last Post: 6th January 2012, 00:22
  5. anyone changed glow plugs on y30dt engine or 3.0 v6 cdti?
    By signum03 in forum Vectra C / Signum Car Chat
    Last Post: 5th May 2011, 15:24
