Thread: head gasket???
    Regular Member coylo5's Avatar
    May 2007
    n.ireland
    Default head gasket???
    if a head gasket is gone. how big of a job is getting it repaired?
    Depends on what the vehicle is and what engine it has but as a rule it's a good days job for most garages ........!!!!!!
    May 2007
    n.ireland
    a v8 range rover. as long as the heads arent warped it should be ok right?
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    My parents 4.0 jeep was in the garage for 3 weeks but most of it was waiting for parts. still about 3 days work tho...
    Regular Member BigLad's Avatar
    Feb 2007
    30,000ft by day, bed at night
    The heads will probably have to be skimmed, most garages take it somewhere else to do it, so probably a couple of days. The wifes Punto blew its HG last year, got it fixed including skimmed for £180
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Do you know which bank? Or are you going to get both done at the same time? If only one is done and they skim the head, make sure they don't take off too much, you DON'T want the banks to have significantly different compression ratios.
    The RV8 is a very forgiving engine, and the heads are fairly easy to get off, and as it's over head valve it won't disturb the cam timing.
    What size is it, and what fuel system, carb or injection?
    Regular Member BIG NEIL's Avatar
    Oct 2007
    Back in Belfast!!!!
    Quote Originally Posted by coylo5 View Post
    bit of a nightmare mate all the bolts have to be replaced and you have to make sure it is done right on those.the best and the cheapest option i would say if can get it to belfast landrover centre out in saintfield those guys really know there stuff and are far cheaper than the likes of hursts and will do a real good job.they looked after my dicovery when i had it and they done a head on my brother in laws diesel range rover.give them a ring for a quote.hope this helps
    May 2007
    n.ireland
    well i havent bought it yet but if i do might just take your advice neil and take it to the pro's in saintfield. least then im covered
  1. Head Gasket gone????
    By ussy2012 in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2012, 16:36
  2. Head gasket ?
    By mrpoochie01 in forum Vectra C / Signum Troubleshooting
    Last Post: 5th May 2012, 15:55
  3. Head Gasket help please !!
    By mark_647 in forum Engine & Drivetrain
    Last Post: 4th April 2009, 11:57
  4. possible head gasket?
    By garvey in forum Engine & Drivetrain
    Last Post: 22nd March 2008, 12:44
  5. Head Gasket
    By VauxVeteran in forum Vectra C / Signum Car Chat
    Last Post: 12th January 2007, 17:28
