Thread: slight oil leak
    Apr 2008
    SOMERSET
    Default slight oil leak
    Hi, Have Just Been Out And Done Oil Change On 1.9 Cdti 150
    And When I Removed The Undertray Found Some Oil Collecting Around The Lower Part Of The Engine At The Back Just By The Oil Filter This Is Not Leaking But Right Awkward To Get To)
    Looks Like Possibly Coming From A Rubber Pipe Whitch Goes Up The Back Of The Engine But I,m Not Sure What To.
    There Is Also An Electric Plug There Aswell, Not Sure What For,whever It,s That Or Not I Can,t Tell.
    Drive Shaft Seals Are Fine.
    Has Any One Any Ideas Or Have Had This Before !!
    Regular Member declanswan's Avatar
    Leeds/tadcaster
    same happened to me???
    South east
    Quote Originally Posted by declanswan View Post
    Did you buy Briane's car off him?
    Leeds/tadcaster
    Quote Originally Posted by Rebellion View Post
    Dont think so!! Unless it was an 05 plate in sapphire black???
    Bristol
    Vehicle : CDTI 150
    My CDTI 150 got an advisory on its first MOT last week for an engine oil leak. Took it to Vx as it still had 2 weeks left on warranty.
    Traced 2 leaks; 1 from the oil filter housing the other from the vac pump.
    They booked 1hr 30 and 2 seals for the job.
    All covered under warranty thankfully.
  1. 2.2 slight oil leak still.......
    By Lordish in forum Engine & Drivetrain
    Last Post: 3rd April 2012, 07:29
  2. Slight Radiator Leak
    By stevie16v in forum General Chat
    Last Post: 19th February 2012, 15:47
  3. slight oil leak
    By srikev in forum Engine & Drivetrain
    Last Post: 18th August 2011, 23:23
  4. Slight oil leak from sump plug.
    By AlexGSi2000 in forum Engine & Drivetrain
    Last Post: 11th July 2011, 22:28
  5. Slight oil leak, 1.9CDTi.
    By pricey in forum Engine & Drivetrain
    Last Post: 22nd May 2008, 19:28
