Results 1 to 10 of 17
Thread: De-Badging
    Regular Member Vectra-c-SRI's Avatar
    May 2008
    Near Glasgow
    Engine : 1.9cdti 8v (120bhp)
    Mileage : 98000
    Default De-Badging
    Hey all, just wondering if you could tell me i would like a nice clean finish on the boot of ma car, wondering if theres a hole behind the badge(griffin).
    Regular Member wardy's Avatar
    Chichester
    apparently not.
    Loads on here have already done it. search the threads & they'll even tell you how to without damaging the paint
    VOTING UKIP IN AVELEY
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    nope no hole just alot of sticky glue
    Swindon
    There are lots of different ways of doing this. Some use heat gun's and different solvents etc.
    Personally i just use a boiling kettle, pour the water slowly over the top of the badge. gently pull at the top until it starts to give, pour a little more water over to melt the glue, and pull a little more. repeat this until the badge if off and then you can remove the glue.
    Follow this up with a clean, and then a nice wax to look totally perfect, and remove and trace of the glue
    Here, there and every where!
    Easiest way to gently prise the badge away is to get either an old credit card behind it or use dental floss or fishing line
    Forum Moderator FIL 4822's Avatar
    On a French Carp lake somewhere x
    6 Post(s)
    Vehicle : Insignia VX-line RED Tourer
    Trim : No, over weight!
    Engine : Flux Core Capacitor
    Year : 1 A.D
    Mileage : Rising
    Or try a Bolster chiesel, industrial strength bleach and a pair of hedge cutters !
    Only kidding it's good for moral !
    Fishing line is easiest way. Warm the badge with a hair dryer first to soften the backing, then a bit if tar remover will shift the sticky left over.
    Regular Member LAV6Y's Avatar
    Oct 2006
    Lisburn, NI
    Can i show you my smooth a*s if you dont mind????
    Attachment 9579
    Griffin and VECTRA removed.
    Piece of cake mate. Boiling water, credit card and Bug and tar remover!!!!
    Chichester
    Now that is a nice a55
    Regular Member JuzzyD's Avatar
    Jun 2006
    Somewhere...
    Quote Originally Posted by tonyt View Post
    Basically what I do - I don't do it straight from the boil though, I leave it for 2-3mins before pouring...
    Regular Member Dwabo's Avatar
    Carterton, Oxfordshire
    hot water over the badge...then dental floss to cut through the foam sticky stuff..then peeled off by heating it up(kettle or hair dryer..then some bug and tar remover to get the tacky bits off)..less chance of marking/chipping the paint that way... try and slice/cut it nearest the badge and not against the paintwork..
  1. Badging
    By Keithy in forum Vectra C / Signum Car Chat
    Last Post: 29th September 2010, 22:34
  2. de badging
    By The Gas Man in forum Styling
    Last Post: 26th July 2010, 09:38
  3. 2.0T SRi Re-badging
    By masj78 in forum Styling
    Last Post: 25th August 2009, 12:02
  4. re-badging
    By keith1983 in forum Styling
    Last Post: 23rd December 2008, 13:43
  5. de badging
    By monkyspunky in forum Vectra C / Signum Car Chat
    Last Post: 27th April 2006, 19:50
