Results 1 to 10 of 13
Thread: gears
    Regular Member howey's Avatar
    Oct 2006
    tyne and wear
    Default gears
    the motor is playing up again lol ....very hard to get into first or second (manual)....is there a hydraulic baring in the clutch? and if so any1 know a price to have this done??? its a 03 2.0 dti
    Regular Member foyboy241177's Avatar
    May 2008
    eastbourne
    ye its a hydrolic relaese bearing its not cheep about 100 quid for the bearing on its own plus the labour to fit book time 5 to 6 hours not a cheap job
    Oct 2006
    tyne and wear
    could it be anything else?
    Oct 2006
    tyne and wear
    where is the resivoir for the hydraulics?
    Regular Member vectra 120's Avatar
    Washington Tyne & Wear
    Looking in the haynes manual hold on check to see if your cars in
    Has the 2.0dti got a F17 0r f40 transmission or any other one?
    Oct 2006
    tyne and wear
    i have no idea
    Well I have the book if you can came around you can have a look m8 if you want.
    Steve
    Quote Originally Posted by howey View Post
    it is combined in with the brake fluid reservoir...
    TBH, if it is just 1st and 2nd thats hard to engage, and 3rd and 4th can be easily 'got' from stationary, then it points more to linkage alignment than a failing release cylinder..
    by all means bleed the release cylinder ( same technique as bleeding brakes) , but if it's just 1st/2nd then i'd get the linkage looked at..
    Regular Member carpet's Avatar
    Jul 2006
    TENTERDEN KENT
    This may confuse you, it did me; the following a boxes for the 2.0 diesel as listed in the Haynes. 2.0 has a F23WR (WR I think is wide ratio). The F17 is for 1.8 petrol and the F40 is for 1.9 diesel. Also inside these boxes you have a range of differing ratios, for instance the F17 comes in both WR and CR(close ratio) versions. Hope this help in some small way with your problem. Regards.
  1. getting gears
    By mitch in forum Engine & Drivetrain
    Last Post: 8th December 2010, 01:43
  2. Not enough gears!
    By Flaninacupboard in forum Vectra C / Signum Car Chat
    Last Post: 17th March 2010, 08:48
  3. How many gears
    By Jason123 in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2009, 10:21
  4. how many gears in the 1.8 vvt?
    By jaff in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2008, 19:09
  5. no gears - help!
    By Digital_kid in forum Engine & Drivetrain
    Last Post: 23rd May 2007, 13:53
