Results 1 to 10 of 19
Thread: Engine misfire on 3.2 v6
    Aug 2006
    Bedfordshire
    Default Engine misfire on 3.2 v6
    Hi guys need some help my vectra C GSi has just started playing up the Control indicator in the dashboard has just started flashing and feels like its only running on 5 cylinders and the symbol in the rev counter is on with the ignition switched on goes out when the engine starts.
    The car only came back from the dealers yesterday to have the handbrake recall done ****** typical.
    Any ideas what I can be, my wife is away on business so I cant get the dealer for a couple of day’s so I still need to use it .
    Mar 2006
    Nicking Ya Dinner.
    Coil pack.
    Regular Member 3.2_V6_VXR's Avatar
    S.Wales, Nr Swansea
    as VV says mate chances are its one of the coil packs, thats what failed on mine
    Kent, UK
    Probably Coil Pack but could be a plug breakdown I guess
    Also could be a sensor gone.
    Best bet is to get it on Tech 2 and find out!
    Regular Member Swatty's Avatar
    Jul 2006
    greenock
    Quote Originally Posted by 3.2_V6_VXR View Post
    Snap, same problem and warning - not the cheapest part to replace
    Kent, UK
    The coil pack on my 1.8 cost me near on £150!
    The amount of money I've spent on the Vec over the years is pretty good though.
    1 x Coil Pack
    1 x Gearbox Repair
    1 x Crankshaft Sensor (30k ago and the camshaft sensor hasn't gone yet!)
    1 x Water Pump (Make sure you always get these changed when you do a cambelt - I figured it would be alright and was pretty lucky just to have to replace the nearly new cambelt and a new waterpump!)
    1 x Unexplained Oil Leak that I'm trying to trace the cause of now!
    Regular Member BlueRob's Avatar
    Jul 2006
    Mexico
    Could be several things mate....from a bad spark plug to a electrical problem or something with the computer itself.
    The only way to find out is to get the codes read.
    HTH
    Regular Member muffking's Avatar
    You can get an ignition spark tester from the Wizards of NOS in Doncaster for a fiver. I used to to diagnose the coil pack on 2 Vectra B GSi's
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Is the ECM dectecting the misfire condition and putting the MIL on?
    Aug 2006
    Bedfordshire
    Thanks Chaps I Have Booked The Car Into The Dealer For Friday Not Driven It Because I Was Worried About Damaging The Cat Etc.
    I Will Let You Know What It Turns Out To Be, But The Coil Pack Sounds Favourite.
    I Don’t Have Much Faith In The Dealer (motorbodies In Luton) The Car Never Idled That Well And They Couldn’t Find Any Problem And When I Had The Cambelt Done The Car Seemed A Little Sluggish Again Couldn’t Find A Problem.
  1. FYI engine misfire / spluttering 3.2
    By DSmiddy in forum Engine & Drivetrain
    Last Post: 4th December 2013, 18:56
  2. Turbo fix - Engine Misfire!!
    By steves in forum Engine & Drivetrain
    Last Post: 1st February 2012, 10:25
  3. engine misfire 30ltr cdti
    By 30ltr nutter in forum Engine & Drivetrain
    Last Post: 19th July 2009, 01:54
  4. engine misfire?
    By littlesxi in forum Diesel Engine related
    Last Post: 1st March 2008, 01:13
  5. Engine misfire? when under load
    By SYMON in forum Engine & Drivetrain
    Last Post: 15th September 2007, 15:09
