Results 1 to 10 of 15
Thread: Brakes i'm confused
    Regular Member shan's Avatar
    Default Brakes i'm confused
    I know people upgrade to 314 mm or similar. But do these also go on the back. So it's all round 314mm and masive calipers.
    I'm not sure what size brakes i have as standard on the front and the back
    I was just looking at LMF and they have 314mm upgrade. Is this 2 calipers and 2 discs and pads ?
    Like i say i'm confused.
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    i think the biggest for the rear is 292mm as big-pete has looked into this him self
    VOTING UKIP IN AVELEY
    18 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    just the fronts Shan ......but some have upgraded the rears ,but not really neccessary
    Here's what I have on my standard V6 CDTI, also fitted to the 2.0 Turbo and 3.2 V6
    Front -
    314mm ventilated discs
    Rear -
    292mm ventilated discs
    On the 1.9 CDTI you have -
    285mm ventilated / 278mm solid
    The only model that differs from any of these is the 2.0 Turbo, which has front -
    302mm ventilated
    Here, there and every where!
    302mm ventilated
    Not strictly true!!!!!
    Early 3.2 GSi's had 302mm fronts as well.
    Quote Originally Posted by shan View Post
    The LMF kit is for the fronts only (the backs work the handbrake too m8 )
    It's a complete it, nowt else required. Biggest rears you can get for yours will be the 292mm vented.
    Do that and you will have some serious stopping power I found that out on Thursday, car stopped in front and i was in my own world For a big old bus it stopped on a sixpence
    yep.. you can't beat bigger stoppers.....
    now looking into 345mm setup for the front of mine as i've got extra power coming.....
    Shan.. get the 314mm kit mate...it's a must....and have a word with chris about the adaptor brackets for the rear calipers...then the 292mm discs and pads will only cost you another £47+V....
    Cheers guy's all noted.
    Mark how much for front discs and pads grooved or drilled one's which is best?
    Chris had his name down allready to do the job
    Just getting myself confused with it all.
    So about 55 quid for discs and pads for the rear and i remeber somebody promising me front 314mm calipers
    And ??? for front vented 314mm discs and pad's
    And ??? for rear adaptor brackets.
    [Ex]Admin Duncan's Avatar
    302mm ventilated
    ...along with 292mm rears.
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    trying to get my 302's fitted and was talking to chris about the 29 for the rear's too, might be an option for me if cheap enough to but without swmbo finding out
    Midlands Mod Shop - NFFC.
    Re-read the original post and you will see that I already included that, it's only the fronts that are different
  1. Replies: 14
    Last Post: 3rd September 2011, 20:23
  2. Confused...
    By danBoy in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2010, 21:14
  3. Confused???
    By monty2000 in forum Vectra C / Signum Car Chat
    Last Post: 19th February 2010, 11:31
  4. Confused with brakes
    By humphshumphs in forum Suspension, Wheels & Brakes
    Last Post: 1st June 2009, 16:58
  5. Confused!
    By siz1 in forum Electrical & ICE (including SatNav)
    Last Post: 18th January 2009, 14:37
