Results 1 to 10 of 24
Thread: rear knocking
    Oct 2007
    nottingham
    Default rear knocking
    i have got rear knocking sound,so have had rear shocks replaced,both rear upper trailing arms[rose bushes] total cost 300 pounds.guess what noise still there on2ltr dti.yes i have checked for loose stuff in boot.anybody any ideas?
    Regular Member joules2.0t's Avatar
    surrey
    Trim : SRI
    Year : 53
    This is a complete shot in the dark, but what about the fuel tank?
    Is it correctly secured?
    Whendoes knocking sound occur?
    Oct 2007
    nottingham
    Default joules
    thanks for reply will look at that.noise occurs all the time on uneven roads but okay on flat terrian.if back seat has passengers in noise not so bad but still there.....
    Regular Member Daywalker's Avatar
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    Could be the lower rear arms or soft springs
    Portadown, N.I.
    I'd say almost certainly it is the rear anti-roll bar bushes that are worn. They cost about £1.00 each and if you can use a torx spanner and a can of WD40, they are fairly easy to replace yourself. Took me about 3/4 of an hour to do both, but if/when I do it again it'll be less than half that.
    Tim
    Oct 2007
    nottingham
    Default Thanks Guys
    could be soft springs makes sense with more compression on them.which ones are the anti rollbar bushes cause am ok with spanners for the price i will change them,is that a dealer price. thanks for advice guys..
    Portadown, N.I.
    Yea, that's how much I paid at the dealers.
    If you take off the rear wheel and follow the anti roll bar around from the short droplink that attached behind the hub, follow it around til it goes through a little metal hoop and rubber bush. That's the ARB bush that will be worn along with its partner on the other side.
    I had the exact same symptoms as you, knocking over rough roads, but the knocking reduced or was eliminated when passengers were in the back. I too had the shocks replaced and the upper control arms ( although both of these were shot on my car and needed replacement ) and the knocking was still there. I changed the ARB bushes and voila!! sweet silence from the back of the car.
    Give the ARB bush holder a good blast wth WD40, esp' the torx bolt, preferably 20-30mins before you start work on it, the torx bolt can be a bit siezed.
    Tim
    edit. As I recall, on mine the bushes looked ok on the car and didnt seem to have much movement, but when I took them off and compared them to the new ones, the old bushes had a oval hole for the bar compared to the round hole on the new bushes.
    Jun 2007
    I would 2nd the anti-roll bar bushes.
    It suprising what a great job a couple of rubber bushes do , but once they have had enough they generally let you know !
    East Midlands
    Quote Originally Posted by HHH View Post
    ?Are the rear ARB the same as the front ones,reason i ask is i bought a set for the fronts but never fitted them,but i too have the bump and bang coming from rear...rear shocks changed on mine (b4s) but still got noise.
    Regular Member Thunder's Avatar
    Apr 2008
    North Yorkshire
    Vehicle : Vectra C Facelift
    Engine : CDTi 150
    Mileage : 71000
    you will have most probably done this,
    Check the two rear seats are locked into the locks
    Mine needed a good thump to lock them
  1. Knocking from the rear?
    By Steven in forum Suspension, Wheels & Brakes
    Last Post: 8th November 2012, 22:49
  2. Knocking on rear
    By richy1974 in forum Suspension, Wheels & Brakes
    Last Post: 18th October 2012, 15:59
  3. rear end knocking
    By rob10 in forum Suspension, Wheels & Brakes
    Last Post: 30th June 2012, 11:32
  4. Rear Knocking
    By yates in forum Suspension, Wheels & Brakes
    Last Post: 25th February 2012, 15:04
  5. rear knocking
    By reeseandellie in forum Suspension, Wheels & Brakes
    Last Post: 7th October 2011, 17:28
