Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: Back from the dealers
    Regular Member 24vElite's Avatar
    Rustington, West Sussex
    Default Back from the dealers
    Got my car back from the dealers after 6 days today. Been diagnosed with the known problem of coolant contaminating the auto. New gearbox and radiator fitted under VX extended warranty (following previous problems).
    Also had an advisory on first MOT of uneven tyre wear, and asked them to look at knocking from rear suspension and 'grinding' noise under braking whilst the car was in.
    They fitted new front brake pads and went round the entire front and rear suspension tightening everything up and greasing where necessary.
    Car was taken to local tyre dealers for full suspension alignment. Apparently the guy took the whole afternoon setting the suspension, balancing the wheels swapping them back to front, rebalancing etc and they still only charged the standard £60.
    What a bl**ding difference that lot made. Car is now completely different, gear changes are as sweet and smooth as anything. No knocks anywhere from the suspension and the car handles so much better. Only driven to and from work today (50 mile round trip) and got 30mpg instead of my normal 27, and that included a couple of instances of 'testing the vehicles capabilities'. Only fault I could mention was a Corsa 1.2 manual as a 'courtesy' car. Apart from that well pleased!
    Regular Member cpt slow's Avatar
    In a house
    What parts did they grease do you know ?
    Not sure exactly - just said they had tightened and greased everything.
    Will have a look underneath at the weekend as it's f.....freezing outside at the mo.
    As capriman, I'd be interested in knowing exactly what they did as I've also got a bit of a knocking noise that I can't work out what it is. Dealer couldn't find anything but I know something isn't right. Difference between driving it every day and dealer taking it for a short test drive!
    In a house
    could be an intersting reply this , I am keeping an eye on this thread as you are too im sure Duncan !
    Quote Originally Posted by 24vElite
    And your point being? Get your a**e out there and have a look for us two - go on!
    - only joking m8. Would certainly appreciate any further info that you may be able to find out from looking underneath or having a chat with the garage.
    In a house
    good point , phone the garage and ask exactly what they greased and tightened . Duncan will then buy you a drink........................( ill just get my coat ).
    Quote Originally Posted by caprimanuk
    Are you maaaad!!! A Scotsman buying someone else a drink!! Jeez, whatever next!!!
    Actually he's right - I would buy you a drink for all your troubles!
    Regular Member POAH's Avatar
    Glasgow
    offended
    Regular Member nellsey's Avatar
    Nov 2005
    berkshire
    Sounds as if they have sorted your car out completely
    Makes a nice change to have the job done properly.
    Gives you renewed enthusiasm
  1. Got my car back from the dealers !!!
    By renton608 in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2011, 10:53
  2. Back in the dealers
    By Gaz the Cab in forum Vectra C / Signum Car Chat
    Last Post: 17th January 2008, 13:15
  3. Back to dealers
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 2nd November 2007, 19:49
  4. Back to the dealers!
    By Big Sig in forum Vectra C / Signum Car Chat
    Last Post: 1st December 2006, 16:20
  5. Car back from dealers today!
    By rushy in forum Vectra C / Signum Car Chat
    Last Post: 17th October 2006, 19:49
