Thread: Power problems on my 1.9CDti (120)
    Regular Member RedLine's Avatar
    Apr 2008
    Liverpool
    Default Power problems on my 1.9CDti (120)
    Hi all,
    I've recently bought a 54-plate 1.9CDti (120) Vectra.
    I've had the car/spanner light on a couple of times on startup but, to be honest, I assumed it was just flashing all the lights up on startup, as it always went off after a couple of seconds. However, now it doesn't come on at all so I'm wondering if something was (IS??) wrong!
    This is coupled with the fact that, between around 1800-2300 revs, on 1/4 to 1/3 throttle, the car "judders", as if it's losing power. This is much worse if the engine's under extra load (e.g. up a hill). If i put my foot hard down there's no problem.
    One option is to just drive it fast everywhere, but I'd rather sort it out! I've tried injector cleaner in the tank (well, you never know...) but no difference.
    Is this the EGR valve problem I've read so much about on here?
    Any pointers greatly appreciated; don't particularly fancy having to hand over a load of cash to a kid with a laptop if I can look at it myself.
    Cheers,
    Ben K.
    Regular Member LJ sxi-nav's Avatar
    Winchester
    wrt the car/spanner light: if it was only on at ignition switch on, and went out after start-up; that would indicate a previous fault logged, but no longer present and it is normal for it to dissappear after a few restarts. (The fault could have happened before you got the car, was no longer present (you just get the light) and now it has successfully restarted a number of times so doesn't warn you anymore).
    Not sure about your other issue.
    Apr 2008
    Liverpool
    Thanks LJ,
    Phew, that's one weight off my mind then... Now, just to sort out the fact that my car drives like it's on kangaroo juice...
    Regular Member Vaux-Man-G's Avatar
    Birmingham
    Quote Originally Posted by RedLine View Post
    Hi all,
    I had the EXACT same problem on mt 54-plate SRI CDTI 120, but after about 40 fresh starts, the light vanished, and still had it tech2 tested but it store dno trouble codes. I would still get it checked ASAP if I were you, at least you know what caused? I was told by the dealer, dont worry about it if it only comes on on ignition, it just means a code sotred, if it were more sever, it would stay on....but it is still wise to check it.
    Apr 2008
    Liverpool
    Hmmm, so it sounds like the spanner light is probably nothing to worry about then?
    In that case, I'm even more curious as to the cause of my apparent fueling problem - odd that it doesn't bring up the ECU light??
    Birmingham
    What do you mean by fueling problem? Do you mean that it doesnt pull....i would still have a Tech2 done on it!
    Regular Member WeDesign's Avatar
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Hi all,
    Cheers,
    Ben K.
    My CDTi 150 had the same sort of problem last week, between 1600rpm and 2000rpm it was juddering, beyond 2000 rpm drove fine.
    Was in the dealers yesterday and they replaced the injector wiring loom which is becoming a common problem on these engines
    HTH
    Apr 2008
    Liverpool
    Morning all,
    re-read my initial description of the problem, and I'm not sure I've described it too accurately...
    Basically, the car loses power for half a second or so, regains it, then loses it, then regains it again. This occurs as it rises through the rev range from 1800-2300 (approx) on part-throttle.
    Feels very much like a fuelling issue (definitely not clutch-related as far as I can make out).
    If it was petrol I'd be checking the plugs etc but, as I've cleaned the injectors I'm stumped!
    Looks like Tech2 is the way to go then... Anyone got an idea of what I should expect to pay for the diagnostic? How about if they replace the injector wiring loom?
    Thanks for the help.
    Apr 2008
    Liverpool
    Well, the mystery might be solved...
    Turbo exploded last week.
    There was a "pop" and a smell of burning, followed by loud whistling when the engine was revved. This didn't last too long as, about 1/4 mile later, there was a loud "bang" and now it sounds like a handful of bolts in a tumble dryer.
    Been told by the garage that the turbo's well shot - quoted £600 for a new one and £600 labour to fit and fish the bits of the old one out of the rest of the motor.
    Does this sound about right??
    May 2008
    Cornwall
    Weel mate. I know how you feel as I have had mine only a few weeks and bang my turbo went as well. I have to pay for it. Ouch!!!
  1. problems with 1.9Cdti 120
    By Kevinw29 in forum Engine & Drivetrain
    Last Post: 5th September 2011, 09:24
  2. Remap Problems 1.9cdti 150
    By SRI-150 in forum Diesel Engine related
    Last Post: 27th January 2011, 18:08
  3. 1.9CDTi starting problems
    By 3961bobking in forum Introduce yourself.
    Last Post: 7th June 2010, 09:26
  4. Vectra C 1.9cdti problems
    By collieq in forum Engine & Drivetrain
    Last Post: 5th February 2010, 01:56
  5. More on 1.9CDTI Auto Box problems
    By richard b in forum Engine & Drivetrain
    Last Post: 25th February 2008, 16:18
burnt wire spanner sign on 2006 vectra 1.9cdti sri 150
