Results 1 to 10 of 16
Thread: which one to go for?
    Regular Member KEV E's Avatar
    Apr 2008
    Wednesfield,Wolverhampton
    confused which one to go for?
    I am a bit stuck on which package to go for there is only a tenner difference in price so that ain't a big deal.Can anybody suggest which is best to go for
    http://www.caraudiocentre.co.uk/prod...00_p-23125.htm
    or
    http://www.caraudiocentre.co.uk/prod...00_p-21386.htm
    thanks KEV.
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    hi i think they are both the same just one is newer than the other any of them would sound great!!!
    Regular Member BIG NEIL's Avatar
    Oct 2007
    Back in Belfast!!!!
    for just a tenner extra i would go for the newer one
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    Go with the full pioneer set up, you will get much better sound quality with an amp that is built for those subs rather than using somebody elses amp that is built for their subs
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    i would go for the second 1 m8 as it comes with the cables aswell
    they would cost alot more £10
    Here, there and every where!
    Quote Originally Posted by glynn View Post
    They both have the same cable kit
    I'd go for the Pioneer amp kit m8
    Regular Member alzsxi's Avatar
    Maidstone, Kent
    I'd go for the all Pioneer set up as well!
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    Pioneer.
    Jul 2006
    Quote Originally Posted by Mugualigwian View Post
    ...you will get much better sound quality with an amp that is built for those subs rather than using somebody elses amp that is built for their subs
    Sorry, but that's cobblers. The only systems that use same-brand gear throughout are for promotions. Any serious (read good quality) setup will have a whole range of manufacturers. Pioneer amps aren't particularly good compared to a lot of others.
    But out of those two I'd go for the Pioneer package too - only because I suspect the Juice amp may fall apart after the 12 month guarantee expires.
    Regular Member Wolf's Avatar
    London
    Do you really need two subs? I am using only 1 of those 12" Pioneer subs with a Kenwood amp and a Pioneer unit and its way to loud. I have set both the unit and the amp on minimum bass just because it's too loud.
